Old 01-06-2012, 12:16 PM   #1
awbrown
sheet metal thickness ?? roof / doors ??
I am going to buy some sheet metal and am not sure of the gauge thickeness I will need ,anyone have any answers??
awbrown is offline   Reply With Quote
Old 01-06-2012, 04:23 PM   #2
1963c-10
1963c-10's Avatar
Re: sheet metal thickness ?? roof / doors ??
Most of the sheet metal on these years is 16-18 guage
1964 Short bed trailer
Old 01-06-2012, 08:05 PM   #3
awbrown
the answer is .035 according to the piece 'I cut out of the roof..... I was asking because I was at work and was going to see the metal supply guy ..I bought 19 gauge . 20 gauge would be the closest at .0359.....
Old 01-06-2012, 08:22 PM   #4
padresag
here is a chart
http://en.wikipedia.org/wiki/Sheet_metal
ron
padresag is offline   Reply With Quote
Old 01-07-2012, 02:06 AM   #5
Captainfab
60-66 Nut
I typically use 18ga.
Old 01-07-2012, 02:12 AM   #6
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
Same here.. Its a little thick for some things if you need to pound and shape it. Also when you weld it to the old metal, make sure you start on the new thicker metal so you dont burn a hole in the old piece..
MOTOIMPAIRED is offline   Reply With Quote
