Old 01-07-2012, 10:09 AM   #1
kellytheaker
87 chev 1/2 350 F/I cold start surging idle
the truck will go to fast idle and then drop to almost stall then pick itsel f up again and continue - when warm it improves but still a surge of up and down - just not as severe - is this an o2 sensor or ? the truck seems to always hunt for an even idle - thanks
kellytheaker is offline   Reply With Quote
Old 01-07-2012, 11:01 AM   #2
ChevyTech
Re: 87 chev 1/2 350 F/I cold start surging idle
A common cause of an idle that hunts up and down on these trucks is a lean fuel mixture, usually from low fuel pressure.
It is also common for the gasket under the TBI unit to leak vacuum causing idle issues.
Here is a thread on this topic:
http://67-72chevytrucks.com/vboard/s...t=surging+idle
Old 01-07-2012, 03:44 PM   #3
kellytheaker
thank you - i will certainly check the fuel pressure , tbi base and reg , then on to additional post info i read the other tips if its not fuel related , thanks it s a start .
