So i got these 80s suburban doors but no hinges off the doors of the suburban, and my 79 hinges will not fit the 80 subrban doors.
So my ? is if i buy the hinges for the 80s doors will it fit my 79 truck body bolt hole ? is there any way i can make these doors fit my 79 ? LMC has two kind of hinges to buy from http://www.lmctruck.com/icatalog/cc/full.aspx?Page=17 Thanks for the info, ![]()
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final." Hunter S THompson |
Re: 80s suburban doors on a 79 Truck ???
That does not make any sense, i put a set of doors on my 77 that came off of a 1990 GMC jimmy, and the 77 hinges bolted right on with no problems. Doors fit like a champ. Are you sure you didnt get the hinges mixed up while swapping them, the tops and bottoms?
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
i didt get the hinge off the 80s doors, and the hinges on the 79 doos will not fit the 80s door. my ? is if buy I some hinges that fit the 80s doors, wil they fit the holes on the 79 body ?
Looking at LMC page it lists door hinges for 73-87 items 5 and 6, an upper lh, upper rh, lower lh and lower rh, so what are you refering to as a 70's and 80's style, its only one style that i see.
Same here, got burb doors from a '89 and they bolted right to my '78 hinges. I think he might of got the top and bottom ones mixed up or something.
![]() 305 ci | TH350 | NP208 | 60k miles |
i'll get pics up 01/07/12
the doors came off a chevy suburban fire truck, i do know if this metters. Thanks for the help guys, I"ll be back with pic on the 07th. Thanks
no help ???
Slots go on anything!
Why don't you think they will fit? The hinges never changed.
1974 Jimmy- 5.3/4L80e/NP241 |
Getting Old; Going Broke
Like everyone else, I'm failing to see why they won't just bolt on.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
yeller
The doors will bolt up, don't worry...once you remove your old doors, you will see....sometimes it's hard to see when things are still on the truck bolted up.
I have mid 80's doors on my 73...and am using my stock 73 hinges I will warn you, the 81+ doors are about 1/4" narrower...so the gap between the fender and door will be slightly wider than it was from the factory (if you are putting newer doors on a 73-80). Actually bugs me looking at my 73, but I can't do anything about it now.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
gets board easy.......
I've always heard about the doors being narrower, but never seen in person.
I put 84 doors on a 77 with orig 77 hinges Posted via Mobile Device |
I think the wiring pass through is throwing your persepctive off. It'll bolt up.
Alex. |
#15 |
Thank you for all your help , I will post pics when i get the doors on . Thank You
