Old 01-09-2012, 12:32 AM   #1
Ray Rust
Ray Rust's Avatar
Leaking pwr steering box
Hi has anybody done just the bottom seal on a 69 C10 pwr steering box , how involved ?? or best way to go about it ??
thanks Ray
Ray Rust is offline   Reply With Quote
Old 01-09-2012, 12:48 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Leaking pwr steering box
All I did with mine is put some Lucas power steering treatment in it... No more leaks...
LockDoc
Leon
Old 01-09-2012, 01:58 AM   #3
Ray Rust
Ray Rust's Avatar
LockDoc
Thanks LockDoc been there done that !! I really think I gonna have to put a new bottom seal in it ....
Ray
Old 01-09-2012, 03:26 AM   #4
sharpmark
this might be of use?
http://www.fourwheeler.com/techartic...ild/index.html
not sure if same box as yours but its a good read anyway
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 01-09-2012, 05:30 AM   #5
Ray Rust
Ray Rust's Avatar
thanks Sharpmark , I read the article but I don't want to have to pull the steering box down ... unless that's the only way ....
thanks again Ray
Old 01-09-2012, 08:56 AM   #6
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Ray,It may be possible to replace the seals on the bottom[sector shaft]while its in the truck but it would be difficult.You are going to have to get the front of the truck raised pretty high because you have to pry the old seals out and hammer the new ones in.Also you will have to remove the sector shaft out of the box in order to access the seals.I just got done rebuilding my entire box and I think it would be easier to just remove it.Just center the steering box,loosen the 4 bolts and it should slide out.You will also have to replace the top seal on the sector shaft cover.Heres a video that help me do it. http://www.mypowerblock.com/video/mu...steering-box-1
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 01-09-2012, 09:30 AM   #7
no moa
no moa's Avatar
Originally Posted by 1970 Bowtie View Post
Great video thank you! I am planning a rebuild for my box.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 01-10-2012, 01:09 AM   #8
grs
My PS box is leaking on my 87. I bought a rebuilt box, and took it to a shop. They will install it far $110.00.
grs is offline   Reply With Quote
Old 01-10-2012, 01:25 AM   #9
Ray Rust
Ray Rust's Avatar
Smile Re: Leaking pwr steering box
Thanks for all the advice .. I bit the bullet ,1 hour and a $3 seal all done , I pulled the Steering box and did it on the bench , pried the bottom seal out punched the new one in jobs done know onto the next leak
