Old 01-10-2012, 07:58 PM   #11
kevinc
kevinc's Avatar
Re: stock tank w/ls1 swap?
Originally Posted by awhite4557 View Post
I removed my factory tank and had it cleaned at a radiator shop. While it was there, I had them weld a bung into the tank and ran my retun line into the tank. When the truck is running, you can't hear the fuel spray into the tank. It works good. My tank builds up preasure after running for a while but I haven't had any problems and have put about 5,000 miles on it.
Would attaching the return line toward the bottom of the tank cause any issues? I just don't want to hear a waterfall behind me.
Secondly, I heard external pumps are not designed to pull thru a pickup tube and they can burn out. On mid to late 80's Ford Bronco's had an external and internal pump. The pump in the tank is a low pressure/high volume pump to get the fuel to the high pressure pump half way up the vehicle which in turn increased the pressure to the engine. I had a 1986 Ford Bronco with fuen injection that ran at 48PSI that had this pump setup with over 145,000 miles. Has anyone came up with a way to implement a low pressure pump in the stock tank to push fuel to the high pressure pump? Thinking this may help extend the life of an external pump.
Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
