Old 12-02-2011, 02:05 PM   #201
laid_out_70
laid_out_70's Avatar
Re: building my first lowered truck
progress from the day b4 yesterday.
First I capped off the lowers
Then I cut out the new gussets
Welded on...
progress on the motor mounts
Love this pic, can see all the holes of the front crossmember, motor mounts and lower link gussets
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob?
http://67-72chevytrucks.com/vboard/s...d.php?t=438132
laid_out_70 is offline   Reply With Quote
Old 12-02-2011, 11:24 PM   #202
laid_out_70
todays progress.
motor mounts are finished up. they drop the motor 2" and push it back an 1"
then had to section the crossmember a bit for the oil pan
pushed the crossmember down a bit to match the slope of the front of the crossmember.
tada
cant even tell its sectioned
then we dropped the motor in
Old 12-03-2011, 02:36 AM   #203
FnLow69
FnLow69's Avatar
Nice fab work! looking good man...
FnLow69 is offline   Reply With Quote
Old 12-03-2011, 10:35 AM   #204
67cheby
67cheby
67cheby's Avatar
looks like everything fits in there GREAT !!
67cheby is offline   Reply With Quote
Old 12-03-2011, 04:48 PM   #205
laid_out_70
thanks guys. going to have to build headers :/. next is the tranny crossmember and hopefully get going on that tomorrow.
Old 12-04-2011, 09:30 PM   #206
laid_out_70
got a few hours in today.
first got all the **** cut out, caps drilled and tapped.
then welded up the ends.
mounting points welded up,
then tacked on
Old 12-20-2011, 06:32 PM   #207
laid_out_70
well ive ordered a quart of semi gloss black POR15 for the frame and a pint of silver POR15 for the arms and links.
anyone that has experience with POR15 have some tips and know how far a quart will get me on the frame? plan on brushing it on by the way.
Old 12-20-2011, 08:57 PM   #208
Cameron 1137
Cameron 1137's Avatar
my one tip: WEAR GLOVES!
that stuff does not come off skin
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 12-20-2011, 10:40 PM   #209
laid_out_70
hah, thank you sir.
Old 01-10-2012, 02:07 AM   #210
laid_out_70
after a month off i finally made it into the shop. first we got the truck on castors
then i got going on the tranny crossmember, plate cut and bent, 1.5" .120 wall tube bent @ 39*
wing notched for the tube
fits titties
tacked on
then welded up
going to run a plate as a back bone along the seam of the tube to the upper mounts i built off of the frame. but next we're having a 40s chevy in the shop for a new floor and some other things, ill post that up as it comes.
also the POR15 i ordered never showed up, looking into that now.
ohh in other news, buddy got cut off and tried to off-road his mini, lol
Old 01-10-2012, 10:52 AM   #211
67cheby
67cheby
67cheby's Avatar
looking good man !!
Old 01-10-2012, 11:43 PM   #212
laid_out_70
thanks slosh-ster
Old 01-10-2012, 11:46 PM   #213
67cheby
67cheby
67cheby's Avatar
Lol. No problem haven't been called that since high school !!
Old 01-11-2012, 12:15 AM   #214
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
was slosh sloshed in High School? haha
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-11-2012, 12:52 PM   #215
67cheby
67cheby
67cheby's Avatar
LOL, my name is Mike Losh
Old 01-13-2012, 10:26 PM   #216
laid_out_70
buddy got bored and built a carrier bearing crossmember for me. some rolled 1" looks titties
Old 01-14-2012, 01:50 AM   #217
67cheby
67cheby
67cheby's Avatar
That's cool looking !!
Old 01-14-2012, 02:09 AM   #218
jbclassix
Junk Yartist
jbclassix's Avatar
nope, tried looking at it upside-down, right-side-up, and and don't see the resemblance... I must be missing something! Cross member looks sick though! are you mounting trailing arms to the x-member also?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-15-2012, 12:38 AM   #219
laid_out_70
dont see a resemblance to what? lol. truck is already 3 links so no trailing arms. if that was the case it would be much beefier.
TODAY:
moved my frame over for the latest. its a 1940's chevy sedan, mustang ll front suspension, buddy linked it last year and now we're mounting the ls1 and trans then doing some work on the floor, maybe more in the future.
first got my turd out of the way
frame in
then assembled
Old 01-16-2012, 03:21 AM   #220
laid_out_70
today first i got the backbone for the tranny crossmember built and welded in. i regret drilling the hole in it but oh well. also the the mitered 2x4 welded to the frame
then started my new back half!
JK
did cut out the tank and compressor mounts though. going to redo them tomorrow
also got the other plate cut out from the carrier bearing crossmember, havent decided on a way to mount it to the frame yet so its just sitting
and my buddy got the motor/tranny mocked up and motor mounts cut out. a work in progress obviously.
front view
Old 01-18-2012, 06:34 PM   #221
laid_out_70
paint is here and i got a job. so now ill have funds for parts but no time to work on the truck. lol. gonna try and bust out what i can of the frame saturday and sunday.
Old 01-22-2012, 10:12 PM   #222
laid_out_70
made some good progress on the truck over the weekend. first i started with redoing the upper bag plates
the old ones with the gussets already cut
decided it would be easier to just cut out that area of the frame and start fresh
then the new piece sectioned in
heres the design my buddy came up with. i like it a lot
next i boxed in the frame from the back of the cab to the wishbone crossmember
all welded up
next is to finish the upper bag plate for the drivers side, then mount the carrier bearing crossmember.
Old 01-23-2012, 11:13 AM   #223
67cheby
67cheby
67cheby's Avatar
nice looking Welds and bag mounts
Old 02-06-2012, 12:19 AM   #224
laid_out_70
progress from this weekend, first i got the carrier bearing crossmember finished. tapped holes in the frame for 3/8" bolts.
also got the other bag plate cut out. mount it next time
and a couple other projects that are at the shop. buddy did most of the tube work and sheetmetal and i made the battery box. lol
fuse box door
next project on the list. sheetmetal floor, firewall and back wall. also misc welding and what not
Old 02-06-2012, 11:01 AM   #225
Cameron 1137
outstanding!
Cam
