01-10-2012, 02:34 AM | #1 |
Fuel Line Fitting
I need a little help with the inverted flare fuel line fitting. The little gasket that went on that fitting is toast (between carb and fitting). I also need a new inlet fitting. Truck is a 65 c20, 283, with I presume the stock rochester carb on it.
So the questions are:
01-10-2012, 09:12 AM | #2 |
Re: Fuel Line Fitting
I used a 5/16 inverted flare fitting on mine made for an auto trans w/barb on the other end....got it from summit for like 4.99. I had trouble finding the larger gasket that goes directly into the carb myself, found an old one on another carb I had. Then I got rid of the hard line and ran rubber in place. ( I wanted a fuel pressure guage and filter inline).
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-10-2012, 10:13 AM | #3 |
You might find your needs here....
http://www.thecarburetorshop.com/Carburetor_ID.htm
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-11-2012, 12:48 AM | #4 |
Thanks. Think I found everything I needed here - http://quadrajetparts.com/rochester-...s-c-72_87.html
