#26 |
Re: Ignition Switch??
LMC Truck looks to carry the same one I have, but better made I am sure. May try that and see. Less than $50 for the whole thing.
#27 |
I wonder if you could use a couple of washers (stainless on the visible side so it will polish and look like a bezel) to "squeeze" the dash hole. This assumes there is enough thread on the shaft that goes thru the dash.
#28 |
I own this AAW switch. In a '55 2nd series (3100), the nut will not go down far enough to squeeze the sheet metal. It will need a spacer in the back.
#29 |
Here is my problem. It seems the epoxy that the PO used finally broke loose. Driving me nuts! It won't tighten up to anything, just flops around.
Shawn 1972 C10 Custom LWB, 3-speed automatic, 350 bored .060 over, Vortec heads, Crane Energizer 260 H10 Cam My Beater/Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=502044 |
#30 |
BIG CHEVY 3600 LONGBOX
If some kind of adhesive is your only solution I would use JB Weld.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
#31 |
Looks to me as if your welds or something broke and it came loose. I'm not sure as I am not very familiar with this era of truck. JB Weld= Bigger the blob, the better the job!
#32 |
I'm going to guess that the original switch wore out many years ago. Then a PO Rube-Goldberg'ed whatever is in there now. If the hole has been enlarged it will have to be welded up and re-drilled, which should not be a big deal.
The LMC catalog has a nice exploded view of the parts you would then need, which would be: 1) 36-0654 - Ignition Switch, V8 $54.95 2) 38-0008 - Bezel - Switch $ 5.95 3) 30-0880 - Retaining Nut $ 8.95 You should be able to use your old lock cylinder, but if not you'll need one of those too: 4) 36-0653 - Ign Lock Cyl w/ Keys $11.95 I'm assuming the Cameo switch is the same as any other 55-59 2nd series since LMC doesn't call out different switches for different models. I'm sure someone here can answer that if it hasn't been answered in this thread already. Here's the link to the page in the catalog: http://www.lmctruck.com/icatalog/ca/full.aspx?Page=69 Good Luck! Bob |
#33 |
There are notches that are visible, so I am assuming it is the original hole. Just not the right parts perhaps. I'll order new ones from LMC and hope for the best.
#34 | |
Let us know when you get it fixed! Regards, Sherlock Holmes Last edited by DransportGarage; 01-11-2012 at 10:57 AM. |
#35 |
That switch looks like it is out of a mid 60s truck I have one in a old cab
#36 |
Wow, that is definitely the wrong one then.
#37 |
Looks to me like it was hogged out like mine, eliminating the stock notch. Don't know if JB Weld, which I am a big fan of, will work in this case it seems to work better at spreading out than adhereing to thin sheetmetal. Any solutions I would offer require some spot welding of reducing washers from the back. I have used the house electrical panel reducer bushing (look like washers with a recessed center) to get stuff to fit in to big of holes when you can get compression from both sides. With out seeing the rest of the switch it is hard to tell if that is viable or not.
#38 |
If it were mine I would get a stock switch from lmc or? And then figure out what would be the best way to make it look right.
One reason I don't worry too much about how i am going to do something is, I think of several ways to do them but I almost always do something different. I don't know if that makes sense. |
