Re: 1965 C-10 LS build
Things to consider when wiring the motor up. Do you want to drill a big 1.5" hole through the firewall? Or do you want to use a plug that seperates it? I'm looking at putting min behind the cab and running the harness over the top of the tran's this way i can just shoot straight down each bank and keep it clean. These motor's look clean if you can either move or dress up the coil pack's.
Just an FYI the Carshop sells 1" set back plates for $45.00 if you need to move the motor back some. To me the front area will be tight. Nice job thus far |
| Bookmarks |
