Old 01-12-2012, 12:03 AM   #1
jstrong394
jstrong394's Avatar
got some bad news for my truck today
Had the guy who was gonna do a little patch work on the back bottom of the cab come over. Showed him the firewall and he said I would be crazy to patch it instead of replacing the cab. Replacing the cab seems like its going to be a helluva a job. Any one tackled this task?
jstrong394 is offline   Reply With Quote
Old 01-12-2012, 12:05 AM   #2
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: got some bad news for my truck today
Realistically, its not all that bad if you have the time for it. Just lots and lots of bolts. Its far less technical then doing patch work. Especially on the firewall.
y5mgisi is offline   Reply With Quote
Old 01-12-2012, 02:24 AM   #3
cory d
cory d's Avatar
the whole nut and bolt part of it sounds fine, its just looking under the dash that intimidates me
cory d is offline   Reply With Quote
Old 01-12-2012, 02:39 AM   #4
rcbildr
rcbildr's Avatar
It's not that bad, really. Grab some masking tape and a marker and make a label for where the wires went.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-12-2012, 02:41 AM   #5
85chevy383
85chevy383's Avatar
Originally Posted by rcbildr View Post
it's not that bad, really. Grab some masking tape and a marker and make a label for where the wires went.
x2
My 85 build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=497551
85chevy383 is offline   Reply With Quote
Old 01-12-2012, 02:42 AM   #6
jstrong394
jstrong394's Avatar
Yeah same here nuts and bolts don't scare me....wires scare me
Old 01-12-2012, 03:17 AM   #7
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
And as far as the wiring goes, if you unhook and disconnect everything and transfer it over directly everything will fall right into place where it needs to go. Years ago I re-wired my old 74 c10 with a harness from an '82 bumper to bumper. It was tedious but it all fell right into place.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-12-2012, 09:55 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
can save a lot of unexpected $$ rust repairs
just take lots of pics
maybe overkill but might wana to take one of each connection/plug moved
add a few more grounds while in there,extra options....
but your in the right place to ask any questions after
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-12-2012, 12:13 PM   #9
maskale
label everything and then take plent of pics from all angles, be sure to get upclose pics so u can really see where things go.
its just labor after that.
maskale is offline   Reply With Quote
Old 01-12-2012, 04:43 PM   #10
jstrong394
jstrong394's Avatar
What about an all new wiring harness.. Lmc's says it doesn't fit the dual headlights and mine is an 84. So does anyone make one for the dual headlights? I will never be allowed to sale this truck so I guess what ever it takes I will do. The pictures seem like a great idea.... They have helped me rebuilt some vintage motorcycles here lately
Old 01-12-2012, 09:21 PM   #11
ghettoluxury
ghettoluxury's Avatar
It is rather easy once you remove the front end and the wires to the engine it is 4 bolts to remove the cab.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-12-2012, 09:31 PM   #12
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
swapping a cab is easy i did it to my truck (first time ever) and it was alot easier than i thought! and fun
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
