Old 09-02-2003, 12:01 AM   #1
Benrs86
Benrs86's Avatar
homemade steering wheel?
hey guys anyone here have a homemade steering wheel? how about some ideas for me? where i work we have small riveters with aluminum flywheels about 15 inches in diameter. i turned one down on a lathe and drilled 8 big holes in it to match my rims but im not sure if i will like it. what other designs would look good?
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 09-02-2003, 12:05 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just kidding. I had to do it though.
Old 09-02-2003, 12:20 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Have you seen those clear arclic(sp) steering wheel's?? How a bout a pic of what you designed.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-02-2003, 01:17 AM   #4
68 Stepside
huh?
68 Stepside's Avatar
A note about the vice grips....they aren't exactly the best tool for driving a car, but it can be done....not that I would personally know though :x
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-02-2003, 06:01 PM   #5
Benrs86
Benrs86's Avatar
never seen the acrylic ones no but i bet they look cool. different atleast. i will get a pic as soon as mine is done. still have to mill the holes/ finish sanding and polish it
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 09-02-2003, 06:08 PM   #6
jcueckert13
jcueckert13's Avatar
I HAVE USED VISE GRIPS TO STEER A CAR ONLY FOR A TEST DRIVE BUT O WELL
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 09-02-2003, 07:23 PM   #7
Jwill41
Jwill41's Avatar
I have been there and back with the vice grips.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 09-02-2003, 10:49 PM   #8
Longhorn Man
I tried to spin out an old Monza I used to have in a gravel parking lot with the vice grip steering wheel too.
I blew the engine up before I lost control.
Best $35 I ever spent. I was almost ready for a small block when i had to ship out for basic training and the apt manager wasn't too fond of the heap just sitting...
Oh well, I was only out 35 bucks and a nice tool.
Old 09-02-2003, 11:32 PM   #9
crazy longhorn
Fabricate till you "puke"
I cant say I have ever used "vice bites" for a steering wheel.......i have welded a couple sets to my truck tho....(its a blind old man deal:p ). Called striking the arc in the wrong spot crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-03-2003, 01:15 AM   #10
casey
casey's Avatar
I remember my older brother and his friends using visegrips on a few of their units back in the 60's, can you imagine how bad you got to abuse your car in the 60's when they were almost indistructable, to have to use visegrips on the wheel, i could never figure that one out
casey is offline   Reply With Quote
