#376 |
Re: What Did You Do With Your Truck Today ?
#377 | |
There are more parts to come...... I am moving and getting rid of the AD parts, I will post them later as I "un cover them" "SOLIDAXLE"
#378 |
#379 |
look nice what are they out of"
#380 |
Sadly I do not know, this guy advertises them once in a while, says he gets them from a guy in LA area that builds show cars, they have been mounted, bases were modified to sit on a flat floor, I can find no manufacturers marks on them. 425 for the set.
Retired and too busy to work. |
#381 |
![]() ![]() Join Date: Nov 2008
Any more pictures on this? I always wonder what guys do after they've completed these kids of repairs to stop that surface rust you can clearly see is still inside? Seems like blasting would work good, followed by rattle can undercoater in there, but of course a good epoxy primer would be better.
Any advice appreciated. |
#382 |
Drove it to work, I did start the install of the new fenders on Sunday, still need to fab up a cpl of fillers for the fenders I measured wrong again. I refuse to post pics 'till I have them finished though. My ego can only take so much damage don't ya know.
#383 | |
#384 | |
#385 |
Dan, I sure hopew so, I'd expect no less
Mark, the tape measure sleeps with the fishes |
#386 |
And good riddance!
#387 |
I worked on my lower control arm hangers and made a template for the frame boxing plates.
#388 |
![]() Join Date: Apr 2009
Got a call from my buddy who is wiring my truck. Its done and i might pick it up this weekend.
![]() then new motor/trans mounts, then the exhaust shop, then the gas tank, then the bed floor, then i'm broke again. Haha! Posted via Mobile Device |
#389 |
#390 |
Spent an hour at the hose shop getting power steering hoses made up. Pick them up today. Trimmed camaro radiator mounting tabs and started removing inside angles on the core support to give room to lower the radiator in. Someday...............
#391 |
I adjusted the pressure in my gm power steering pump today.Installed 3 shims and now the mustang power rack is alot happier with lowered pressure.
#392 | |
catchy name and they used to have a great calendar.
#393 |
Got it back from my buddy chris who re-wired it for me. I drove it up and down the street just so the neighbors would know its back.
![]() got a lot of work ahead on this sucker. If i can get home in daylight ill get some new pics and get a build thread started. Posted via Mobile Device Last edited by meter swinger; 01-16-2012 at 01:31 AM. Reason: + |
#394 |
Found it is still behind all the office junk in my garage. Did clean up the Chevelle for next Saturdays breakfast with the SW Idaho region guys!
#395 |
Just ordered new engine/trans crossmembers and mounts. The first step in many of a badly needed rehab for this sucker.
#396 |
Got my interior pretty much wrapped up in my 54... Still have to make kick panels and finish the wiring..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#397 | |
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
#398 |
Finished welding/grinding the last of my door rust repairs!!
#399 |
Tried to go outside, gave up, went back to bed, watching Barrett-Jackson now.
#400 | |
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
