Old 01-05-2012, 10:12 PM   #1
dyno
dyno's Avatar
58/64 Stepside bed interchange?
I'm needing a step side short box for my 58 GMC. I found a nice bed that came off a 64 Chevy. What's the difference? Looking on-line I see the fenders and tailgate are the same, but bed sides may be different. Thanks.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 01-05-2012, 10:39 PM   #2
G&R's57GMC
G&R's57GMC's Avatar
Re: 58/64 Stepside bed interchange?
Same, go for it.
G&R's57GMC is offline   Reply With Quote
Old 01-05-2012, 11:48 PM   #3
bfink
i think they are the same bed and fenders from 55 2nd series up to 66
bfink is offline   Reply With Quote
Old 01-06-2012, 12:29 AM   #4
dyno
dyno's Avatar
I thought they were the same and they probably are. However, I looked at the Brother's catalog and they show a side bed panel for 55-59 and a different one for 60-66. All other bed parts are the same.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 01-10-2012, 12:58 PM   #5
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Here is a link to our article on bedside interchangeability--hope this helps you out. Best of luck with your build!
http://www.mar-k.com/bed_side_interchange_gm.html (short bed)
http://www.mar-k.com/bed_side_interchange_long_gm.html (long bed)
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 01-10-2012, 05:53 PM   #6
Maximus
Maximus's Avatar
One thing to look at is the frame width. I got a 1959 truck in parts, and the bed wouldn't fit on the truck... the rear cross brace that the license plate would bolt to, it has two brackets that bolt the back of the bed to the frame, and this spacing was completely off, i'm assuming it was a bed from a 60-66 truck ... I bought a replacement panel from a supplier so no big deal, just be sure to measure the back brackets that bolt to the frame to find out if you need to replace it or cut the brackets and re-weld them...
this is the piece i'm referring to...
Maximus is offline   Reply With Quote
Old 01-10-2012, 10:26 PM   #7
dyno
dyno's Avatar
Thanks guys...I will call Mar-k in the morning. Looks like there will be a problem with the rear cross brace according to their info.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 01-10-2012, 11:59 PM   #8
8baller
did the 58 have a bed on it?..
8baller is offline   Reply With Quote
Old 01-11-2012, 12:32 AM   #9
dyno
dyno's Avatar
It had a 8' fleetside on it. Shortening the frame for the stepside bed.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 01-13-2012, 12:45 AM   #10
Maximus
Maximus's Avatar
if the bed was priced right and in good shape, the cross brace is only like $90+shipping... for mine i have to cut the factory welds that are on the crossbrace-to-bedside area. for some reason mine was bolted and welded...
