Old 08-28-2003, 01:59 PM   #1
shortbed70
shortbed70's Avatar
2 12bolt housings w/gears
I've got two rear ends I need to get rid of one has a richmond 4.56 gear but the carrier is trash. Housing is cracked but gears ok. The other has an open 3.73 gear mostly complete but needs new bearings and seals. They must go I'm tired of them taking up usefull space. asking $50 dollers for the richmond and make offer on 3.73.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-28-2003, 02:53 PM   #2
bigjimzlll
bigjimzlll's Avatar
Is the 4.56 a 12 bolt truck ? with a series 4 carrier...If so I would like to buy the gear set
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-02-2003, 08:57 PM   #3
shortbed70
shortbed70's Avatar
Soory it took so long to get back my internet got shut off. I'm not sure on the carrier but it is a 12 bolt truck rear. It came out of my 65. The carrier isn't in the gratest of shape it broke the cross pin bolt and broke the spider gears(2) The gears seem to have no vissible damage thats why I'm selling for 50. You would probably want to take it appart and look at it closer because whomever set it up had too much play in the pinion gear and it rubbed the carrier.
Troy
Big Red Dog build
