01-11-2012, 08:17 AM | #1 |
C35 Crew Dually
moving hanger and shackles
Will moving the hanger and shackle up one hole on the frame work on my one ton? I know it works on 1/2 tons thanks
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
01-12-2012, 08:19 PM | #2 |
C35 Crew Dually
Re: moving hanger and shackles
lol anyone?
01-12-2012, 09:15 PM | #3 |
Yes you will gain about 3 inches.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-12-2012, 09:20 PM | #4 |
C35 Crew Dually
thanks because with the springs i have in my truck it sits 3inch higher than it should after i put drop hanger and shackles.
01-12-2012, 09:34 PM | #5 |
C35 Crew Dually
do you move both up? because i just looked at my pics and my shakle holder has only 4 rivits....
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 01-12-2012 at 09:40 PM. |
01-12-2012, 09:36 PM | #6 |
yes you have to grind the heads of the rivits off and punch them through the frame then replace with Grade 8 bolts.
01-12-2012, 09:39 PM | #7 |
C35 Crew Dually
no i know that as i did that with my hanger but if i move the shackle hanger up only 2 holes with be lined up with the frame will only 2 be enough? lol noticed i missed some info in my last post fixed it now.
01-13-2012, 12:38 PM | #8 |
Happy to be here
No, two is not enough. You will need to drill two new holes.
01-13-2012, 12:42 PM | #9 |
C35 Crew Dually
thanks but i just was looking under the truck and i have to do a stock spring pack swap as my 2inch shackles already almost hit the bed floor
01-13-2012, 01:23 PM | #10 |
Ya in the rear you have to do shackles or move them , one or the other not both
01-13-2012, 01:26 PM | #11 |
C35 Crew Dually
the prob is the ark are my springs because it use to be a tow truck and had 26 leafs aside :S
01-13-2012, 01:42 PM | #12 |
Had the same springs in mine when I did my BUDGET drop. Ended up taking out 16 leafs, i would have to go look in the snow bank. Replaced the centering pin, used STOCK shackles and moved BOTH hangers up the frame. Not as low as I want it but it works for now.
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!" Last edited by Racker; 01-13-2012 at 01:59 PM. |
01-13-2012, 01:43 PM | #13 |
C35 Crew Dually
yeah i took 20 leafs aside out and used 2inch shakles and 2inch hangers but i still have 3 inch wheel gap
01-13-2012, 02:03 PM | #14 |
Holly Cow, I'm guessing mine where a little softer than yours. Have you moved the hangers up yet?
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!" |
01-13-2012, 02:04 PM | #15 |
C35 Crew Dually
no cant the shackle is already almost touching the bed.
01-13-2012, 02:26 PM | #16 |
Just read your WHOLE rig build up. And then went and looked at mine. YEP, my springs settled out more like the other guys. If you got a good yard around the area, I would go and look for a set of 3/4 ton springs. Might cost up a little money but a lot less work. Just my opion to help out a fellow dually.
01-13-2012, 02:35 PM | #17 | |
C35 Crew Dually
01-13-2012, 08:07 PM | #18 |
I beleive the will, dont see why they wouldn't. Or see about getting some one ton leafs that dont have as much arch as yours does. Just trying to help but depending on how low you want to go, I say BAG IT. That is where I'm headed with mine. Good luck and GREAT work so for.
