Old 01-15-2012, 01:48 AM   #1
rbar
rbar's Avatar
Alan Grove brackets
Test fitted my Alan Grove brackets today. Since I don't have bolt holes in the heads of the '65 corvette 327 I picked up, I put these brackets on. They worked out very well and I was impressed enough that I might put them on my 383 as well. Now I have to decide if I am going to powder coat or plate them. The engine is dusty from sitting in storage, but rebuilt. Got a suprise when I found that one of the bottom holes in the block was stripped out. Thank goodness for heli-coils.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 01-15-2012, 02:17 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Alan Grove brackets
Originally Posted by rbar View Post
Test fitted my Alan Grove brackets today. Now I have to decide if I am going to powder coat or plate them.
I purchased Alan Grove brackets back in 2000 and had them powder coated before installation. Other than grime from use, they look like new when cleaned up. Since the metal is so thick it really heats up nicely and does a great job curing the powder paint. Plating would certainly add more sparkle if it's in the budget.
Old 01-15-2012, 02:21 AM   #3
rbar
rbar's Avatar
I'm talking zinc plate vs powder coating. I can do either one of those two at no cost.
1965 Chevy swb 383
Old 01-15-2012, 02:40 AM   #4
padresag
they show that alt bracket only for the long w/pump
ron
padresag is offline   Reply With Quote
Old 01-15-2012, 02:48 AM   #5
Rich 5150 69
Rich 5150 69's Avatar
ron
I believe that is what he has ron...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-15-2012, 03:02 AM   #6
padresag
I was just going by application and the year of engine
thks
ron
Old 01-15-2012, 03:23 AM   #7
Rich 5150 69
thks
ron
Hey by the way what you been working on lately....ron, I not sure you`ve posted a project lately...?
Old 01-15-2012, 09:17 AM   #8
northern 85
northern 85's Avatar
I really like the brackets, did you buy it as a kit?
northern 85 is offline   Reply With Quote
Old 01-15-2012, 11:45 AM   #9
rbar
rbar's Avatar
Yes, from Alan Groves components. It's for long water pump only. It's $70 for the steering pump. It's $45 for the alternator, but if you don't have a bolt hole in the head, then you have to buy the $25 bracket that goes on the back side of the alternator and uses the two bolts that hold the water pump on. It was all $152 shipped.
1965 Chevy swb 383
Old 01-15-2012, 11:57 AM   #10
protrash64
Resistance is Futile
protrash64's Avatar
rbar, is there a bracket on the back of the power steering pump?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-15-2012, 12:18 PM   #11
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Looks good
I have a Alan Grove A/C compressor bracket and it is a quality piece.
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 01-15-2012, 12:27 PM   #12
chevyrestoguy
chevyrestoguy's Avatar
The long pump normally works with the thick balancer. The 327s had the thin balancer. How did you work out the issue with pulley/belt alignment? I tried that on my own years ago, and it was a nightmare. Does Grove make brackets specifically for that application? I would have paid huge money for those back in 1984......
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-15-2012, 03:12 PM   #13
rbar
rbar's Avatar
Yes, it looks just like the "triangle" shape that is on the front of the block and it is flat against the block mounting holes, but one plate is 3/16" thick and the other 1/4". It is very sturdy, at least when I try to move it around by hand.
1965 Chevy swb 383
Old 01-15-2012, 03:21 PM   #14
rbar
rbar's Avatar
I used a 350 balancer, found true TDC, and put a new TDC timing mark on it due to them being clocked different. My 327 damper was very thin and small in diameter and had the pulley bolt holes all stripped out. Other than the 400 version and the various degree marks, they are interchangable. The engine is internally balanced and the "balancer" is really a harmonic damper. I haven't ran this engine yet, but I have done this once before on a 327 with no issues. They do have a few other options for short pump mounting, some really low mount and some really high mount.
1965 Chevy swb 383
