Old 01-16-2012, 12:37 PM   #1
m455sx
m455sx's Avatar
Interior Help
I just got my pick up friday and it will need a steering wheel, the one that is on it is hidious. I am 6'2 and will need tilt steering, will a factory steering wheel work on a IDIDIT steering colomn? Also want to get factory guages and add a tach?? Also i would like to know all the best places to locate these parts?
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 01-16-2012, 01:08 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Interior Help
I know for certain that won't work. These trucks were made for people 5'9" and under so how bout' you send it over here so my vertically challenged self can drive it?
Just kidding, man that thing is CLEAN! I really have no idea about the column, but do know that alot of guys use the van tilt columns with little modification. I do know that even at 5'9", I would really like a tilt setup. I can only imagine being 6'2" and being crammed behind that wheel.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-16-2012, 01:35 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Interior Help
A factory wheel will be bigger and stick out further.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-16-2012, 01:45 PM   #4
punk17
punk17's Avatar
Re: Interior Help
Nice looking truck! I have same problem going to maybe cut my bench seat frame And lower it. I have seen some cut stock Colums down.has anybody. Cut a stock streeing wheel down?
punk17 is offline   Reply With Quote
Old 01-17-2012, 08:32 AM   #5
m455sx
m455sx's Avatar
Re: Interior Help
I have been looking at a IDIDIT steering colomn but it doesn't mention that it bolts to the factory steering wheel. I just want a factory wheel with the horn ring, what years will match original? I know 65 and 66 are different but i do not know the difference. I will settle for a 65 or so as there may not be much difference.
1970 Cutlass SX
1962 Chevy Stepside
Old 01-17-2012, 10:05 AM   #6
1963c-10
1963c-10's Avatar
Re: Interior Help
Bowtie bits LLC has refurbished guage clusters (but not cheap) in stock, or find a used unit and refurbish it yourself. You will have to do some wire conversion to switch from factory warning lights to guages. The tachs can be found aftermarket through most venders...the original EB-8 suntachs are harder to come by. I did my own guages and replaced all the harness's, but have the list of what needs swapped to keep the existing harness.
1964 Short bed trailer
Old 01-17-2012, 10:09 AM   #7
1963c-10
1963c-10's Avatar
Re: Interior Help
Glad you finally got the 62, great looking truck that you've got there.
Old 01-17-2012, 11:32 AM   #8
1963c-10
1963c-10's Avatar
Re: Interior Help
To convert from warning lights to guages: parts required - Guage cluster, under-dash wiring harness, instrument panel wiring harness, engine harness, alternator harness, temp sending unit, plumbing for oil pressure guage. Also note that the L6 and V8 engine harness's are different. The oil pressure guage is mechanical so no wiring is required there. The temp guage wiring harness has only one wire to the sending unit, the warning light cluster has two. The alternative is to modify your existing harness. It involves adding a few extra wires and unhooking some others. The oil sending wire and one of the temp sender wires are no longer needed. The ammeter also has to be wired. The fuel guage is the same on either cluster as is the speedometer. The tach is easy to wire...the ground is through the metal dash and the power wire plugs into the fuse panel, the sensor wire is hooked to the negative side of the coil. I found it easier to just replace the wiring, but was more costly....pretty much just plug and play though.
