Old 01-18-2012, 09:00 PM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Factory Air Cleaner Housing Differences?
Are there any differences in stock air cleaner housings for small block V8 engines in our trucks from 67-72? I'm particularly interested in a 72 350...thanks for any input
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-19-2012, 12:07 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Factory Air Cleaner Housing Differences?
If I remember correctly, Other than 2bbl or 4bbl, 67's are pretty much by themselves, (different carb) 68's (federal) did not have the "thermactor" flap and the snout was different. 69-72's are the same..
Livrat is offline   Reply With Quote
Old 01-19-2012, 01:00 AM   #3
FirstOwner69
FirstOwner69's Avatar
I'm pretty sure the the 3/4 and 1/2 ton trucks used different housings for at least some of those years due to more stringent emissions requirements for the lighter duty 1/2 tons. All my California built and sold 69 3/4 ton has for emissions is a PCV valve and valve cover to carb breather hose.
FirstOwner69 is offline   Reply With Quote
Old 01-19-2012, 01:10 AM   #4
stomper
Junior Member
stomper's Avatar
At my local O'Rileys Auto Parts there is a unique part number for the 72 K5 350 air filter. It's a little taller than the other filter that is listed for the C/K 10-30's. I have a factory air cleaner assembly supposedly off a 72 C20 350 and the taller filter listed for K5 will not allow the lid to seal on the base.
"I was patina when patina wasn't cool."
1973 Cheyenne Super SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 01-19-2012, 08:45 AM   #5
mrein3
mrein3's Avatar
I purchased a stock 4bbl air cleaner off the parts board here about a year before I built my 383. I was in collect parts mode. I figured they were all the same so I didn't ask if it was off a 4x4 or not. When I finally got around to putting that stock air cleaner on my installed engine, it hit the firewall so I had to use something else.
Other than my experience I have no proof that there are differences. Not too many days ago "too much stuff" posted a picture of three different sizes of carb spacers. Perhaps 4x4s need the shorter spacer to clear the firewall for the farther back stock SBC location. It wouldn't have take a much shorter spacer for my stock air cleaner to clear.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-19-2012, 09:50 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Any pictures of the differences??
Geoff with a G
