Old 01-19-2012, 09:13 PM   #1
turner16
Power Locks not working
I just got my 96 on the road and have some problems of course. This is the newest truck I've ever owned.
My power locks are dead, both switches both sides. Where do I start to troubleshoot this?
turner16 is offline   Reply With Quote
Old 01-19-2012, 11:26 PM   #2
Legolas894
Chemist under the hood...
Legolas894's Avatar
Re: Power Locks not working
Assuming no blown fuses, there's a black relay underneath in about the centre of the dash (I think it says Potter and Brumfield). See if that clicks when you push the buttons. Could be the buttons too but unlikely that both are bad.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 01-19-2012, 11:31 PM   #3
bwood
bwood's Avatar
I was also thinking that if the driver's side switch failed, it make both switches not work. I think I ran into this when I install my keyless entry.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 01-22-2012, 02:43 AM   #4
turner16
I think I may start with the switch. If that relay is located anywhere close to where it was on my 80 it will be lots of fun finding and changing it. Unless GM made removal able AC vent and but it right there? Now that would be nice.
Old 01-22-2012, 10:41 AM   #5
mountie
mountie's Avatar
When I changed out my driver's door lock switch, then both doors locked again.
$20 (LMC Parts) for each door switch. Use a putty knife to remove the switch, & just plug in the new one.
mountie is offline   Reply With Quote
Old 01-22-2012, 11:32 PM   #6
Legolas894
Legolas894's Avatar
On m '98 Suburban, the relay was almost in the centre of the dash if you went up towards the radio. It's clipped to something else as I recall. My locks would sometime stay energized (in the unlock position), draining the battery.
Current fleet:
Old 01-23-2012, 09:24 AM   #7
mountie
mountie's Avatar
the door switches are simple rocker switches. They can get stuck in a position, (inside, & behind the decorative outer switch cover your finger touches)...
Draining the battery.
My window switch used to be a "one-touch" up. Just touch the switch, remove your finger & the window would raise all the way up with no pressure from your finger.
Old 01-27-2012, 12:11 AM   #8
BP68
BP68's Avatar
Check the fuses in the left IP fuse block on left side of dash. I am a gm tech and have seen the locks quit on these when the cig lighter fuse is blown. I never figured out how that ckt related to the locks, but it would be easy for you to check. I think it was labeled cig. Just check all the fuses and see if this helps.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 01-27-2012, 09:25 AM   #9
mountie
mountie's Avatar
My passenger door window & lock didn't work until I replaced those switches. Even the driver's side switch, for the passenger door didn't work until the passenger switches were changed.
(Thanks LMC for the parts)
Old 01-29-2012, 01:17 AM   #10
bighaas79
check for broken wires in the harness of the door jambs too.
bighaas79 is offline   Reply With Quote
Old 02-03-2012, 10:22 AM   #11
baclay9
My cig lighter fuse was blown and was keeping the door locks from working. I had to take it to a dealer because I couldn't figure it out. I would have never dreamed it was hooked up to the cig lighter fuse!
baclay9 is offline   Reply With Quote
Old 02-03-2012, 04:40 PM   #12
turner16
OMG my lighter won't work either!
Checking the fuse first thing
