![]() Join Date: Jan 2009
'72 Blazer 4wd getting all the best
Ok well here we go, I have had this Blazer for a little over a year now, and have been gathering up just about everything under the sun that I have liked, found on the threads or other wise and it is time to get it going. I will post as I go, but I don't have as much time as I use to, and getting it to work on a build is going to get a little shorter as a New addition to the family is coming.
So Here we go. The Blazer was bought with a little rust needed has been sitting for 11 year and then before that it was barley driven at all. No special order Blazer or nothing. It came to me like this and then trying to organize the pieces I just purchased. So the plan is to Drop a LS-1 with a 4L60 & 246 transfer case. The idea is to have push button 4wd on the fly. So the delema was to find a front axle that would allow for Drivers drop, and that will be a '79 f250 with high piņon so might as well go 8 lug for a nice wheel. The other delima is crossmember for both the LS-1 and the 4L60. Well I found a CCP universal LS-1 cross member that works great with a little modification. and well we just built one for the 4L60e. I will post as many pictures as I can, but right now it is in the begging were we all have to start. |
Re: '72 Blazer 4wd getting all the best
New Axles, 1979 F-250 for the Drivers side drop.
Build Thread, |
Remove all you can, to put it all back and then remove again to put back, you know the routine.
Build Thread, |
The New Dif. Covers, Thanks Riddler, these are awesome
Build Thread, |
The Motor & the crossmember from CCP . Smoking deal on this find sorry the guys girlfriend wrecked his car, but lucky for me.
The New front seats 2009 Cadillac Escalade 2nd Row so the fold up like the original ones
Build Thread, Last edited by jstplyn331; 02-08-2012 at 07:14 PM. |
Making sure the wheel I want will fit, Size of wheel and tire this is not the one I want, it is a friends off his truck. Letting me use to see how it looks.
Got the New Headers, after about 3 different name brand tries these ones are made from a guy on Ebay, and are the nicest and not to forget the least expensive. Also got the Intake Hydro dipped and the 4 core radiator with electric fans.
The New Billet Dash Panel, Made from Ryan Hubbard, he is right here on these forums and makes these I contacted him to make me one that will have a Dakota Digital Dash Insert for the Shift indictor that will be a little cleaner then the Clock in the Middle and clean up the steering column.
http://67-72chevytrucks.com/vboard/s...=409114&page=2 |
The Trans. Crossmember
Nice conversion.
Do you by chance remember who you bought your headers from exactly? Or if you know the application they are for, that would help also. Just trying to save a lot of hassle on what fits for the LS series swaps. Thanks! |
#12 | |
I don't see them in his store anymore, but if you email and ask him about getting a pair I bet he could I only paid 189.00 for them that is 1/4 the price of any other good pair I tried and he was the only one that had the dimensions. http://www.ebay.com/sch/fastksguy/m....84.m1439.l2654
Build Thread, |
Thanks, I will try emailing and see what he has available.
VA72C10
![]() Join Date: Mar 2008
Nice Build!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#15 |
Build Thread, |
#16 |
Super nice build you have going. Good luck
#17 | |
![]() Join Date: Jul 2009
I just checked his page and he has a set of long tube headers for a Camaro..? Is that what you purchased or was it listed as something different..? Thanks in advance.. Nice build BTW.. I actaully was thinking about the same thing this morning in regards to the push button 4wd and started researching anc came across your project...but I am not sure what all is involved yet at this point.. I understand there is a Transfer case motor, seperate PCM, wheel hubs that have an eletrical connections and then obvioulsy the switch to be installed in the dash somewhere where it won't be hit by accident while driving... Anything else missing... I have an NP208 case already but that will have to go I guess.. I have a 72' GMC Jimmy that I am restoring as well...
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. ![]() |
#18 | |
This was what the Title on EBAY Was and the item number. Send this to the guy and ask if he can make another set. "LS1 LS6 Stainless Shorty Chevrolet Engine Swap Header (160622579516)" Here is the link for the Push button start, They have been highly recommended over the Japanese companies, They might come with Alarm. But not sure they work. http://www.myStarDrive.com/stardrive..._ignition.html
Build Thread, |
#19 |
nice build, ford axles? Interesting.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#20 |
Doing about 3 weeks of axle research, it was the only one that would fit correctly with out modifying the crap out of it, it was also quad piston, High pinion, drivers side drop. I could also take the auto locking hubs form a corporate and put them in to work with what I was looking for. WIth all that said, Yes unfortunately I had to go Ford on a Chevy, but have been told this is a great axle.
Too much research ![]() ![]()
Build Thread, Last edited by jstplyn331; 02-06-2012 at 08:09 PM. |
#21 |
If I may ask, which push button setup are you going with... Also, could you outline all the items that are required for such a conversion..? I am on the fence in regards to going this direction as I have read over several forums where folks just do not like to deal with the problems associated with the electric push button option.. Maybe there were certain models/years they had issues with - who knows.. I just want something that is dependable..
Also you mentioned the ford axles were 8 lug.. I really want to keep my old school 5 spoke rims that are 6 lug.. Do they make any kind of conversion..
#22 | |
If you are looking to due a push button 4wd they are all off either a chevy or ford I think even a jeep, but anyway they are all drivers side drop. In order to to this you will need a front axle with a drivers side housing. I prefer the 8 lug wheels better so I stepped up to the ford axle with the high piņon. As far as axles go I research the crap out of them for what I wanted and would recommend you do the same if you want to due this for a 6 lug similar set up. This web site is probably the best you will find for axle help. http://77cj.littlekeylime.com/web_rs44.html you will find this guy must have got really board and wanted to post anything and everything to help out people like us, AND for that I thank him. The NP246 I have been told is a good transfer case it just needs the updated pickup pump inside cause they go out all the time. The button config. will be the stock one that is used for the same truck. The fun part is getting it to work with the computer. I will bypass the computer and put in a alternating toggle switch. This will have to be switched to on to trick the TCCM and allow the tach speed wire to know it is all ok to engage. This is something I am still working on, but I may have found a way to input the speed wire from the computer harness in to work the same way as stock on would. Not sure if this what you were asking, but here you go and hope it helped.
Build Thread, |
#23 |
Just ordered up the Guages, Ow they are going to be sweet.......
Build Thread, |
#24 |
Don't for get the Ididit Column, w/ the Billet specialties Chycayne Steering Wheel wrapped in the Carbon fiber.....
Build Thread, |
#25 |
interesting, nice
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
