Old 01-19-2012, 10:02 AM   #1
jsw72c10
wiring harness/firewall question
I've decided to go ahead and go with new wiring for my 72 .i think im going with painless and just wondering does the firewall mount cover the existing oe cut out or should i patch it. i havent ordered anything yet just thought i'd get a head start. thanks for any help
jsw72c10 is offline   Reply With Quote
Old 01-19-2012, 10:11 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: wiring harness/firewall question
I believe you will have to widen it just a little...they include a template for you to use in the kit....I think they have the installation manual online for you to look at as well...the template is in there...here you go...http://www.painlessperformance.com/Manuals/10206.pdf page #24 check the part number you are using and find the correct manual
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-19-2012, 10:42 AM   #3
Daddy Brim
Daddy Brim's Avatar
I put one in my truck about a year ago, and yes you will need to make the hole bigger. I would suggest soldering and use heat shrink tubes on all connections.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 01-19-2012, 10:47 AM   #4
jsw72c10
thanks abunch
Old 01-19-2012, 05:06 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
FYI...if you have your old harness, be sure to keep it....you'll need a couple of the connectors that are not supplied with the painless kit...
Geoff with a G
Old 01-19-2012, 05:11 PM   #6
webfoot
If its going to be totally stock I'd consider a kit from AAW or M&H wiring.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 01-19-2012, 09:47 PM   #7
BuiltwithIvy
My .02, save the money, buy the cheaper kit from speedway, use all your factory switches, and run the wires where the can't be seen...
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 01-20-2012, 10:30 AM   #8
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
X2
Tom Vogel is offline   Reply With Quote
