#26 |
Even so, 30K miles on a farm are hard miles. Hows it look underneath? All the cab supports, mounts etc. in good shape? Also, check the bolt channels inside the rear wheel well tubs. A truck doesn't necessarily have to be moving all its life to rust out.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
#27 |
Wow, cool! I didn't know there were any V6's offered. I thought there were only inline 6's and V8s!
What a fupid stuck eh? ![]() Brian |
#28 | ||
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#29 |
My 71 4x4 has 60,000 miles, and it isn't a farm truck, the motor has never been apart, I found a good way to tell if your truck has more miles than it might say, I took my truck in to get one back spring rearched, and the spring man took the leaf apart, and said to me this must be a low mileage truck, I said why do you ask, he said you see where theses leafs over lap each other, on a higher mileage truck the end of the leaf wears a good size groove in the leaf above it, theses are like new, and they have never been out
#30 |
go cyclones
Good tip casey
#31 |
Good tip thanks
#32 |
![]() Join Date: Apr 2003
Thanks for the tip, casey,
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
#33 |
Damn, I would have never thought of that.
#34 |
That V6 will run forever. You really can't break them. They're modified from a diesel design and everything in them is super heavy-duty. I had one in a 66 GMC and it got 14 mpg uphill or downhill, load or no load.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#35 |
Everything sounds good
#36 |
I don't know exactly how many miles my truck has on it but I do know that I have only put about 13-14K miles on it in the approximately 18 years that I have had it. It was an old truck when I got it and I bought it just to be a 3rd vehicle - sort of a backup and junk hauler locally. I have had it as far as 200 miles from home but only twice in that 18 years. Mostly it sits - outside- and the paint has about had it just from age. Low low miles is not impossible but one should look real real close for signs to justify the claim.
1968 Chevy - 292 with a powerglide |
