Old 05-13-2011, 12:04 AM   #1
67 project
Power Brakes and Original Drums?
Hello Everyone,
Anyone know if you can add power brakes to a 67 with a I6 and a 3 on the tree tranny?
Would like to do something that I can handle (newbie). Any pics of your setups would be appreciated.
Also if anyone has suggestions on how to best do this I would also appreciate it.
David
67 project is offline   Reply With Quote
Old 05-13-2011, 10:53 AM   #2
StingRay
StingRay's Avatar
Re: Power Brakes and Original Drums?
Really easy. Most of the half or 3/4 ton boosters should work. Just make sure that the push rod from the booster to the master cylinder is the correct length. You can make the 73-87 boosters work pretty easy too but you will have to do a small amount of modification to it to make it work. If you happen come out this way I'll give you a 73-87 that's already modified. I have some 67-72 models as well but the price wouldn't be quite as good LOL. Scott's Super Trucks in Penhold probably has used stuff around or will be able to hook you up with somebody that does.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-13-2011, 11:26 AM   #3
ChevyLvr4Life
ChevyLvr4Life's Avatar
I'm getting ready to do this swap myself. Already have a new booster, just trying to find the time to do it. Ditto on the booster push rod to master cylinder length. My booster has really short push rod, and my master cylinder uses a longer push rod. I'm gonna have to create a filler/extension to compensate for the deep hole in the master cylinder and the short push rod on the booster. I have read that you don't have to disconnect any of the lines to the master cylinder to install the booster, just unbolt MC from firewall carefully push it forward, bolt on booster, then attach MC to booster. Here's a good link on how to install...
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
1970 Chevy C10 LWB 307 3OTT 3.73 gear
ChevyLvr4Life is offline   Reply With Quote
Old 05-13-2011, 12:20 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
That is correct, just unbolt the master with the lines intact and CAREFULLY pull it forward. Also you may need the linkage rod that goes to the brake pedal unless yours is adjustable.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-13-2011, 01:41 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
I blew apart a stock drum without power, going down the highway. Make sure everything else is in good working order. I am running disc now.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-13-2011, 04:50 PM   #6
dmack91
dmack91's Avatar
If you have all the parts, it is a quick hour or less job.
Best mod I did to mine.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 05-13-2011, 06:35 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Just so you know,this is a snowball job.The booster works fine but there isn't room for a stockk air filter assembly.You will either need a factory offset one or aftermarket.I suggest the aftermarket to start with so you can drive it while you find and offset one if you want a stock set-up.There should be a port(plugged) under the carb that will work for vac.I got the fitting at the LPS.If you change the booster rod and need to unbolt the rod end from the pedal,you will either have to drop the column or remove the spring(before mounting the booster) so the pedal will swing down to acess that bolt.(It's a shoulder bolt).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-13-2011, 10:12 PM   #8
pritch
pritch's Avatar
If you use this booster:
And this air cleaner:
They fit! I just don't have a picture of the two of them together.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 05-14-2011, 11:42 PM   #9
pritch
pritch's Avatar
Here-I took this today:
Not a very good close-up:
There is a-dimple-(for lack of a better word) on the bottom of the air cleaner. It clears by a good quarter inch.
'68 Panel
'68 C-10
Ol' Green
Old 05-15-2011, 11:44 AM   #10
67 project
Coming up your way to a wedding in PA in August. Maybe I could meet up with you on the way through.
Thanks for the info.
David
Old 01-21-2012, 05:57 PM   #11
67 project
Was wondering if your offer for a brake booster still stands? If you can pack it up and send it via greyhound I would pay for the shipping. Let me know StingRay.
Thanks for the help.
