Old 01-19-2012, 11:50 PM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Need pictures of where my A/C hoses go
Hi, looking to use the docsblocks extensions listed from Glock's Fred build on my compressor in the stock position on a 2004 6.0L motor....
Need to see some good pictures of what frame mods people did or how they ran their lines.
Would also like comments and pictures of what lines and hoses to where?
Feel free to draw arrows on my pics if it helps...I have been searching the forum and net today without much luck on finding instructions.
Thanks in advance!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-21-2012, 09:39 PM   #2
clinebarger
Re: Need pictures of where my A/C hoses go
The black arrow is the Suction side (Low side) hooks the the accumulator.
The yellow arrow is the Discharge side (high side) hooks to the condenser.
The white line is where you will have to notch, take as little of the frame that you can.
Couldnt get good pics, Its dark.
clinebarger is offline   Reply With Quote
Old 01-21-2012, 11:30 PM   #3
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I forgot to get the pics for you. However, the pictures above are correct. I used the factory hoses from 6.0 and had the ends changed to match my older system. I spent about $90 for all of it. The hose place was able to un-solder the 6.0 ends and turn them the way I needed them... Looks factory!
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 01-22-2012, 12:36 AM   #4
paul mora
I am doing the same conversion, what headers are you using?
Pulatoy
paul mora is offline   Reply With Quote
Old 01-22-2012, 05:05 PM   #5
Gordonr1973
Home Built '87
Speed & Performance
Gordon
Old 01-22-2012, 05:06 PM   #6
Gordonr1973
Home Built '87
Cline & Having some fun: thanks for the good info, I will get some hoses made up and post pics in my build thread!
Thanks again!!
Gordon
