Old 01-23-2012, 02:03 AM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: My 66 GMC LWB
After searching these forums for a couple days for lengthening the booster rod and mounting the booster, and running the lines, I ran across a post by you that lead me to your build thread.
Thanks for all the pics.
They help a lot.
I got all my stuff off a 79, so I will be doing it the way you did.
Originally Posted by AZ66GMC View Post
It's been awhile... a long while...
Work has been killing me and never have spare time to work on the truck... I did finally find time to get the engine/tranny resealed and back into the truck. I plumbed the brake lines and buttoned up the front suspension. It just needs an alignment and bleed the brakes.
I need to get the drive shaft shorten due to swapping in the 700R4. Also need a new dip stick tub as the one that came with the tranny has a split in it...
I also modified the AC compressor mounting system so that I can install my 14" air cleaner. The original location for the compressor was on top and to the right of the bracket and put this compressor on top of the intake right in front of the carb. I mounted the compressor on the opposite side and used a bracket to put the adjuster bolt on the left instead of the right. Looks much better now and my air cleaner has plenty of room
Tony
Mine:
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-23-2012, 11:57 PM   #2
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: My 66 GMC LWB
They help a lot.
Mine:
Cool I'm glad it was helpful. That's what I like about this site, great info and ideas, sweet rides, and cool peeps
Looks like you got it mounted up. Looks great. I notched my steering column plate to clear the bottom right booster bolt hole and then drilled the firewall for both bottom bolts. It's pretty solid.
I have to remove mine again to repaint... The master cylinder startd leaking from the back...
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
