Parking Brake Cables
Hi Guys, got a 71 4X4, Corp 14 Bolt rear, w bolt on type e brake cables, they look to be 6-8 in short from the bracket where the old ones clipped on the truck, the ones that came w the truck, I still have those too but were 1/2 ton w snap in on backing plate instead of bolts, any ideas guys, I suppose I could move the brackets on the frame but....... is there longer cables avail?
Re: Parking Brake Cables
Hi i had the same problem i finaly found a set they are old new stock company name EIS part#2785 there is another number very small on box 95m18rb . before i found these i thought about using the cable bolt up ears that came on the 14 bolt corp rear end and fit them to the 1/2 ton break cable it looks like it will work wish you the best of luck rusty
did you find them yet?
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
