Old 01-17-2012, 09:11 PM   #1
JRANGER
JRANGER's Avatar
Dash Pad Removal?
How in the heck do you remove the bolts above the passenger side? They seem to be sunk in and unreachable by socket....I dont want to rip them out and not be able to mount it back in properly..
Also tried needle nose pliers with no luck
Thanks in advance
JRANGER is offline   Reply With Quote
Old 01-17-2012, 10:06 PM   #2
6772fan
Active Member
6772fan's Avatar
Re: Dash Pad Removal?
I've had good success with using a small socket and just forcing it on there. That's probably just vinyl material that's wrapped around the bolt head. I don't recall the socket size, but as I recall it's metric- around 8 or 10 mm. Be gentle and it shouldn't do any big damage to the dash pad. There's metal frame behind it so it should go back on just fine and not be noticeable when re-installed.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 01-17-2012, 10:08 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
yup push in a bit...7mm or 9/32 i think......8 is 5/16
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-17-2012, 10:20 PM   #4
joe231
joe231's Avatar
Yeah what was said above. I use a 1/4" ratchet, extension, and a 7mm or 9/32" socket (if it has the original screws.
Just push and the soft area around the screw head will compress. They screw into plastic inserts that push into holes in the metal dash. They shouldn't be very tight.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-17-2012, 10:39 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
I had a bit changing screwdriver (I think that's what it's called. screwdriver that allows phillips head bits to fit in it?) and it was the correct size of the screws. The heads were recessed so you just had to put pressure on them to find the head and then just unscrew.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-17-2012, 11:01 PM   #6
JRANGER
JRANGER's Avatar
yup got it out
Old 01-17-2012, 11:07 PM   #7
JRANGER
JRANGER's Avatar
Here it is...****ty as hell but I laid the cover on it to see its future glory!!! lol Just gotta cut down the high spots clean in and adhere the cover
Old 01-18-2012, 12:36 AM   #8
JRANGER
JRANGER's Avatar
man that insert was jacked!! lol it has to be replaced
Old 01-24-2012, 12:07 PM   #9
broey
Square
broey's Avatar
looks sweet, If you dont mind me making a suggestion, I would use a fabric paint or any paint that will adhere to the old dash and paint the edges that have a chance at being exposed black.. If thats even a possibility. Im not sure if the new cover wraps around or stops at the edges.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-24-2012, 12:13 PM   #10
JRANGER
JRANGER's Avatar
It fits pretty good except on the very back edges and of course where the trim goes..
Thanks for the suggestion! I will probably look into that..
