Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-24-2012, 02:03 PM   #1
bigboybodry
bigboybodry's Avatar
Re: 28 10.5 tires
thank guys I going to need all the help I can get going from a 31x10.5w to a 28x10.5. I was thinking along the lines of a 3.50 gear to start?
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-24-2012, 02:23 PM   #2
kpeztruck
kpeztruck's Avatar
Re: 28 10.5 tires
What kind of class you running? Heads up, index, bracket? If heads up, I would not switch to such a tall gear. I plan to run the same tire on my truck, with a 540 BBC on one fogger with a large tune up. I have the MSD 7531 to help manage power, as well as some chassis and engine tricks. The converter will also have to be correct for the combo, but you can fly on a 28x10.5 tire, and still run the proper gear to pull hard through the finish line. Paul
kpeztruck is offline   Reply With Quote
Old 01-24-2012, 02:44 PM   #3
bigboybodry
Re: 28 10.5 tires
heads up. my combo ended up being a 512 with a pro shot fogger on bottom and sportsman up top, th400 with brake custom, bte custom nos converter and still running a 12 bolt 35 spline axles full spool and 390 gear.
Old 01-24-2012, 08:05 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 28 10.5 tires
The 2.48 over the 3.90 is alot of mechanical advantage . Did they specify 28" or just say true 10.5 ? If just a true run a 29.5 . I would test with the 3.90 , but your on the right track . I came up with 3.40 with a 28 " tire and 400 . I had a 3.60 in the garage , so i'll probably be heading that direction .
X2 on the ignition box and pulling timing .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-24-2012, 08:59 PM   #5
bigboybodry
Re: 28 10.5 tires
they said max 28x10.5 no w's
