Old 01-27-2012, 10:45 AM   #1
funkytechmonkey
funkytechmonkey's Avatar
shortening elevel wiring a good idea?
After installing my accuair elevel sensors I have about 3-4 feet of coiled up wire on each corner.. that I have to tuck and hide up in my frame. I would really like to clean this up and make it look nicer. Is it possible to splice these wires and make them shorter? I've called accuair and left 3 messages for a tech to call me back and I have still not heard from them. My bro-inlaw is an electrician so I know we can do it the right way with the shrink wrap water proof connectors. Is that a bad idea? Anyone else done this and run into problems?
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 01-27-2012, 11:35 AM   #2
dv8customs
dv8customs's Avatar
Re: shortening elevel wiring a good idea?
There should be no problem as long as you make good solder connections and then protect it from the elements.
dv8customs is offline   Reply With Quote
Old 01-27-2012, 11:37 AM   #3
big_al_71
big_al_71's Avatar
We have modified harnesses many times as long as the wire inside is not a fibe roptic wire you should be fine. Looking at the wires on my E3 leveling sensors they do not look to be that kind so I would guess yes you can, however quadruple check before you cut.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
