Little help please
OK, so I am looking for a few parts and need to know the best place to get them. A good set of complete body mount kit with all new hardware. And, where can I get a new nice set of hood hinges??? 1970 Chevy c-10 1/2 ton
Thanks |
Lemme show you something!!
Re: Little help please
Any of the board vendors (GMCpauls, Brothers, Ecklers, LMC, Classic Industries, etc.) will have the varous cab, core support and bed mounting bushings and bolts.
For the hood hinges you can certainly get stock replacments at the above mentioned purveyors or if you want something more "custom" there are a couple options. Cowl mounted, gas spring, super trick, high quality, a must for layed out rides, hinges are available from the world famous Nate Porter @ Porterbuilt http://www.porterbuiltfabrication.co...tarting-at-265 Original style scissor action but made from billet aluminum with gas springs instead of coil springs are available from Eddie Motorsport. http://www.eddiemotorsports.com/stor...&p=26932&c=395
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
X2^. Dingfodgy's got you covered. You could also get a pair of good used hinges, but they are hard to find. Just make sure they are not bent or twisted, and the rivets are not loose. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
Still plays with trucks
http://www.streetsideauto.com/p/ener...ension-34108g/
Use coupon code "smartshopper" and it will knock 10% off. Totally free shipping with no handling charge like Summit & Jegs. They came with the rear bolts on the C20 set I ordered but you may need to get all the hardware with the C10 set.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
