Old 01-27-2012, 08:25 PM   #301
(joey)
(joey)'s Avatar
Re: Project...praise the lowered
Originally Posted by slick copper View Post
Wish I had my garage so you could come down with it!
As far as the steering wheel, I'm pretty sure most chevy's have the same spline there's a few different ones, but camaro wheels fit our stock columns. Here's a thread that talks about some different steering wheels. One guys says 88-up are the same. Maybe this'll help ya out some.http://67-72chevytrucks.com/vboard/s...steering+wheel
thanks slick.i will check it out.on a side note,i think i now have both box sides str8.i got to put in a few hours today.also blocked the high build on the hood.looks great.im going way overkill on the blocking but it will be worth it in the end.back at it tomorrow.its good to have weekends back
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 01-27-2012, 08:41 PM   #302
kev2809
low n' slo
kev2809's Avatar
Na. Ima leave it..if it was on the outside I would fix it. But it only being on the firewall, I'm not too concerned about it.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-30-2012, 08:25 PM   #303
(joey)
(joey)'s Avatar
i managed to get a little more done.i did some more blocking and got both box sides ,the cowl,and pass door panel in high build.after a little sanding one box side is ready for paint and after i fill a low spot on the other it will be ready to spray..im finally on the down hill with the box side adventure.
Old 02-01-2012, 07:40 AM   #304
slick copper
slick copper's Avatar
Looking good! Yeah paint work always comes out good when you put in the time to do the prep work.
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 02-02-2012, 08:13 PM   #305
(joey)
(joey)'s Avatar
it really does .getting the box sides in paint will be a huge step.
on a side note im going a different master cylinder route.i now have one of these on the way.should solve my bleeding and minimum space problem..
Old 02-03-2012, 06:13 AM   #306
slick copper
Sweet MC/Booster combo! I'm wanting something like that on mine when I get to that point. Gonna convert mine to disc/disc on of these days.
Raymond
Old 02-05-2012, 04:18 PM   #307
(joey)
(joey)'s Avatar
so after blocking a couple last spots on the box side i still wasnt happy with the upper body line .it was driving me nuts.it was probably good enough for paint but i couldnt sleep until i did something about it.so for anyone thats reading this build thread and have decided to cut down a long box into a short im really going to save you some shaping time.it is really really hard to get that body line consistent and straight.sanding blocks are just too hard to shape with.what i did was bought a paint roller with a plastic inner.take a torch and melt down the outer fuzzy part.when it cools enough to handle heat one side enough so its soft enough to shape.then on a good part of your box press the heated soft side of the roller into the contour.let it cool and you now have the perfect shaped sanding block.in my pics you can see the low spots that were just not quite perfect.i wish i made this when i was shaping the lower body lines on my doors.it would have saved so much time.
Old 02-08-2012, 07:22 PM   #308
(joey)
(joey)'s Avatar
after what seams years of blocking im finally happy enough with the outside of both box sides to spray them.im just going to hold off until i get the inner sides hacked up and skinned with new sheet metal.also tonight i finished my inner door panels.used the john deere blitz black and did the insert with the speckle paint.sorry for the pics.they were with my cell phone.
Old 02-09-2012, 02:35 AM   #309
VA72C10
VA72C10
VA72C10's Avatar
Door panels came out looking very cool!
Old 02-09-2012, 06:05 AM   #310
(joey)
(joey)'s Avatar
thanks.they look alot better in person.i will get some pics when i get them on the doors.
Old 02-19-2012, 06:14 PM   #311
(joey)
(joey)'s Avatar
so i finally gained some on the build this week.i managed to do some sheet metal trimming on the inner panels of both box sides,ordered in 3 lengths of 1x1 and 3 lengths of1x2 steel tubing for my box sides and floor frame.in the pictures you can see when i trimmed the inner box sides and on the underside i spot welded 1x1 tubing to give it plenty of strength to stay upright when i weld them to the bed floor frame.for the openings im going to mount some stainless or aluminum for a nice clean look.i also welded my front tubing in place for the custom front bed panel.on top of all this i hung the tail gate and started fixing dents.the old girl was well used.not sure if i posted this before but in the pics you can see the custom tailgate latch release i made when i shaved the original one.really feels like im getting somewhere again\
Old 02-19-2012, 09:57 PM   #312
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
good to see ya making some progress again! we've been waiting!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 02-20-2012, 12:20 AM   #313
YBNORML
YBNORML's Avatar
Awesome build!! Took me almost an hour to read the whole thread, definately worth it.
Looking forward to some more updates.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-20-2012, 02:26 AM   #314
chevy88
chevy88's Avatar
Nice build, lots of ingenuity here.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 02-20-2012, 05:58 PM   #315
(joey)
(joey)'s Avatar
slow going but speeding up again.i plan to have the rest of the truck trailered back to my buddys place this weekend.then the sparks will really fly
Old 02-20-2012, 06:01 PM   #316
(joey)
(joey)'s Avatar
welcome to the build guys.it gets my a$$ back in gear knowing i have more people following.stick around,shes finally coming to an end.
Old 02-22-2012, 11:02 AM   #317
Gokart Mozart
another subscribed
I like the idea of the chrome parts from the old mixed with the JDBB and the hood is killer!
Gokart Mozart is offline   Reply With Quote
Old 02-22-2012, 11:07 AM   #318
67cheby
67cheby
67cheby's Avatar
do you have a closer pic of you tailgate latch ? looks pretty cool !
67cheby is offline   Reply With Quote
Old 02-22-2012, 06:38 PM   #319
(joey)
(joey)'s Avatar
Originally Posted by Gokart Mozart View Post
another subscribed
thanks.it should be a good combo all together.i actually had to paint the door handles and headlight buckets for now.they were more rusty then i thought.they will have to do until i order new ones
Old 02-22-2012, 06:41 PM   #320
(joey)
(joey)'s Avatar
i dont think i have a close up.if i think of it tomorrow i will snap one for you.its kind of like a twist latch.it was one of the first mods i did when i started this project many moons ago
Old 02-23-2012, 07:11 AM   #321
slick copper
Good progress! Can't wait to see it all together man!
Raymond
Old 02-23-2012, 06:30 PM   #322
(joey)
(joey)'s Avatar
sorry cheby,i didnt make it to the shop today.i will try for tomorrow.
and as always ....thanks for the kind words slick copper,im so excited to finally get to the home stretch.then the real fun begins.
Old 02-24-2012, 07:49 PM   #323
(joey)
(joey)'s Avatar
got them cheby.it was just something quick and clean i made to relocate the latch to the inside
Old 02-24-2012, 08:10 PM   #324
67cheby
67cheby
67cheby's Avatar
pretty neat, a simple cool idea !
Old 02-24-2012, 08:29 PM   #325
VA72C10
VA72C10
VA72C10's Avatar
That's cool. Simple and clean!
