Old 01-30-2012, 03:17 AM   #1
low&slow
Electric vs Manual Fuel Pumps
So I'm planning on putting a fuel cell in my truck one of these days and was curious about the fuel pump options. Do I have to run an electric pump or can I use the normal pump on the engine block?
And which is better and why?
low&slow is offline   Reply With Quote
Old 01-30-2012, 10:23 AM   #2
MARKDTN
Re: Electric vs Manual Fuel Pumps
You can use a "regular" pump on a fuel cell.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-30-2012, 10:39 AM   #3
cdowns
cdowns's Avatar
mechanical fuel pumps are one of the most reliable units ever designed// no reason with a carb to run anything but
Old 01-30-2012, 11:00 AM   #4
68Gold/white
If your pickup is just a driver, maybe a once in a while quarter mile pass, the mechanical pump, is simple, and will work fine.
Eletrical pumps serve a good purpose when needed in higher performance applications. I like things simple, every chance I get.
68Gold/white is offline   Reply With Quote
Old 01-30-2012, 11:45 AM   #5
eurospec1
eurospec1's Avatar
Yep i yanked the electric pump out of my truck and put a mechanical back on it as soon as i bought it, keep it simple, they just work
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 01-30-2012, 01:45 PM   #6
mrein3
mrein3's Avatar
And if you're out on the road and have an issue with a mechanical, stock fuel pump, you're an auto parts store away from getting a stock replacement off the shelf.
If you have a whizz-bang googleplex super duper fuel dumper and it goes out you'll have to wait for Summit to bring you a new one which may destroy a trip.
I replaced the stock fuel pump on my truck in Deer River, Minnesota. I limped into town and found the auto parts store on main street. I installed the pump in the back lot. Total down time about 30 minutes.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-30-2012, 01:53 PM   #7
hopped up
hopped up's Avatar
go with a mechanical pump. electric fuel pumps always decide to go out at the worst times. in my opinion mechanical pumps last much longer too
hopped up is offline   Reply With Quote
Old 01-30-2012, 05:08 PM   #8
chopnchaneled
chopnchaneled's Avatar
Agree X's 100
I wish i could run a mechanical but i'm running a vortech 350 and have to use an electric pump and your right they do go out and its always at a bad time. always have a spare under the seat.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 01-30-2012, 06:42 PM   #9
crazy longhorn
Fabricate till you "puke"
I have a stock AC Delco on my 383(specs in my sig).....I have never seen the old stroker to starve for fuel. The stock pump puts out 5 1/2-6 psi. Last trip out, the youngest kid was playin....@ 125 mph in 5th gear, I told him ....you have 2 choices, either back it down, or shift OD, & drop the hammer. On the way back, that lill bioch was in OD & I layed the hammer down. 6000 rpms in 5th gear is about 125 in that old truck....on the ride back in, I had her a tick over 140 in OD, & that stock AC Delco pump was still hangin 1 hp per cube, you are probably fine with the stock mechanical pump......if you have more hp than that, you might go elect. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-30-2012, 07:16 PM   #10
davepl
davepl's Avatar
The only reason I run an electric pump on non-injected cars is when the block isn't cast for one, like the old ZZ502s. Mechanical pumps are infinitely quieter and hassle-free.
I've got an Aeromotive A1300 pump in one car that's good for about 1500hp, and wound up adding a pump controller and moving it in-tank just to dampen the noise. So I use them were I have to, but given a choice always pick mechanical.
davepl is offline   Reply With Quote
Old 02-01-2012, 02:30 AM   #11
low&slow
Awesome. Thanks for all the inputs. The truck is not going to be a daily driver or driven on the street at all. It's strictly going to be a drag truck. And right now all I'm running is a 500 cadi. All stock other than an aluminum high rise intake. Truck is pretty much gutted out and is a long bed, so I just wasn't to sure about the fuel pump situation, but thanks again.
Old 02-01-2012, 05:51 AM   #12
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
mine leaked a bit after 40 years. still ran just leaked a bit. bellow pumps will pump mud and never jam
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
