Old 02-01-2012, 09:23 PM   #1
Squareforceone
Squareforceone's Avatar
Re: Scary Bed Floor
That's what happens iowa is the same damn way, not to jack your thread but does anyone know where (if) you can buy bed supports my frame and bed floor are in great shape but there are a couple of spots in the the supports where it's started to rust through and i don't see the point in replacing the whole floor since it's solid otherwise
Squareforceone is offline   Reply With Quote
Old 02-01-2012, 09:29 PM   #2
78K20
78K20's Avatar
Re: Scary Bed Floor
Originally Posted by squareforceone View Post
that's what happens iowa is the same damn way, not to jack your thread but does anyone know where (if) you can buy bed supports my frame and bed floor are in great shape but there are a couple of spots in the the supports where it's started to rust through and i don't see the point in replacing the whole floor since it's solid otherwise
lmc ?
78K20 350 / 400TH 3:73's, Dual Polly tanks, my old plow Trk. Now parting out.
84K20 6.2 "J" Code Diesel / 700R / 4:10's
78K20 454/400TH 3:73's Dual tanks (my new plow rig)
78K20 is offline   Reply With Quote
Old 02-01-2012, 09:42 PM   #3
Car'n'Guitars
Car'n'Guitars's Avatar
Re: Scary Bed Floor
No I'm absolutely sure they don't make them for fleetsides, but someone please correct if I'm wrong.
Originally Posted by 78K20 View Post
I live in the rust belt too. I've been thru what you are dealing with and I
suggest that when you replace your bed with another, you seam seal all the edges where your cross supports meet the bed floor. Also clean & coat the bottom side before you install. I use a product called "ZERORUST". It is available in several colors. I use red & black. First I paint with the black, then I switch to red. That way, I get full coverage. A couple coats is all you need. The good thing about RUSTFREE, is you can always touch up any problem area's later. Not so, with products like POR15.
I have a 78K20 that's been my plow rig for many years. I got tired of fuel tank's rotting out, so I switched over to polly tanks. You may consider doing the same.
Just sayin'.
Yeah I had plans on doing that when I get a new bed and cleaning up the frame too. Your in La Porte that's not too far from here. It's been a long time since I have been there. And everything will be considered when redoing my truck, don't want it to rust out in 10 years.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
