Old 09-06-2003, 09:43 AM   #1
brad20653
Whats this wire ?
Theres a black wire coming from the wires that run on top of the radiator it has a rubber thing connected at each end to put them together and is hanging by the battery what could it be ? What do i do with it ? is it hot or ground looks like it would go to that thing on the fender that holds the hot wire from the battey ??
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 09-06-2003, 10:20 AM   #2
cdowns
cdowns's Avatar
those "rubber thingys" are fuse holders the black goes on the junction terminal on the fender
Old 09-06-2003, 10:23 AM   #3
brad20653
do u know what size fuse i put in there ? What does it run ??
Old 09-06-2003, 11:26 AM   #4
jhow66
jhow66's Avatar
4 Amp--goes thru your amp gauge
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-06-2003, 11:27 AM   #5
brad20653
Does that wire not being hooked up have anything to do with my rear lights not working ?
Old 09-06-2003, 11:35 AM   #6
jhow66
jhow66's Avatar
Not that I know of--if I remember right it only protects the gauge . The 4 wire harness (green, yellow, brown, ?) that comes out of firewall next to gas linkage is what feeds your rear lights-check it out -maybe loose somewhere.
