Old 01-25-2012, 09:07 PM   #776
kev2809
low n' slo
kev2809's Avatar
Re: My 68 swb build.
man that column looks good...
truck is turning out nice man..i like it!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-25-2012, 09:21 PM   #777
rob32472
I ordered the same column for my build....... don't think u can beat it for the price
rob32472 is offline   Reply With Quote
Old 01-25-2012, 10:50 PM   #778
77chris03
77chris03's Avatar
It's all stainless minus the adapter...I think ill get over it.
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 01-25-2012, 10:51 PM   #779
77chris03
77chris03's Avatar
Thanks bro. Maybe u can see it in person if u ever make it this way
Old 01-26-2012, 12:27 AM   #780
tll74
"Junkyard Dog"
tll74's Avatar
Nice job so far. Love the look of the grill!
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 01-26-2012, 01:54 AM   #781
68 TT
Still plays with trucks
68 TT's Avatar
The column looks great. I might have to get me one.
Have you looked it over to see if a stock NSS can be fit to it?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-26-2012, 08:05 AM   #782
77chris03
77chris03's Avatar
theres no place for a nss, so im still pondering cutting the column to add one...i think the diameter of the shaft is the same size so it might not be a problem, but just the thought of cutting up a new column disgusts me slightly...the only real reason i want the nss is for reverse lights..
Old 01-26-2012, 05:54 PM   #783
68 TT
68 TT's Avatar
I'm sure you could rig up a micro switch on the trans linkage to trip the reverse lights instead, or even just put a toggle switch in for them.
Old 01-27-2012, 08:35 AM   #784
77chris03
77chris03's Avatar
didnt get but one pic last nite, but its nothing extravagant... managed to get the pressure line for the powersteering done...i found a hose that works, i hope. the return line may be a little high, but im gonna leave it until i get inner fenders.
got my other steering column torn apart and got all the rubber and steel mounts off of it and transferred to the new column. was gonna put it in, but tuckers truck parts sent me the wrong u joint for the gearbox...i will be calling to get the right one...
and lastly i got the ebrake pedal assy somewhat finished...had to cut it 2 inches or so to clear the shaved firewall...welded it up and ground the out side smooth. I hope this works cause this cab is no way a 69 because the mounting point under the drivers vent is not there. the hole is not drilled through and the roll on the bottom of the dash is the same the whole length of the dash...took a pair of vise grips and bent that sucker over so it would fit...all thats left is drill the holes for the mounting studs, hole for the cable, blast, paint and install...
Old 01-29-2012, 02:34 AM   #785
77chris03
77chris03's Avatar
got these in friday...too bad the gearbox is the wrong size so i gotta send it back to get the right one...didnt know the spline was a 5/8"...
Old 01-29-2012, 02:36 AM   #786
77chris03
77chris03's Avatar
got it drawn and cut...not that pretty but i did what i could with what i had...
got the tab tack welded in...next i have to drill and tap the holes for the mounting...
Old 01-29-2012, 04:50 AM   #787
chevy88
chevy88's Avatar
Was kinda wondering if anyone was actually following my thread. Kinda losing my motivation.
Keep up the great work, for every 100 that look at your thread only about 1 will post so believe me that people are definately interested.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 01-29-2012, 05:09 AM   #788
68 TT
68 TT's Avatar
Thanks for being brave and cutting into that column. Now I know what to do to make it work
Old 01-29-2012, 09:36 AM   #789
rob32472
Looks good! And I dont see anything wrong with what you have done.... A little thought can save a lot of money.....
Old 01-29-2012, 01:31 PM   #790
77chris03
77chris03's Avatar
right....lol it took me a few mins to realize im gonna cut it up...lol i think its gonna work...honestly looking at it, i dont think it matters where you put it just make sure that you weld the tab in the correct place.. what ive found is as long as the opening is the correct size and the tab is welded 1/2 inch on the park side...if that makes sense...
Old 01-29-2012, 01:32 PM   #791
77chris03
77chris03's Avatar
yup yup, i just hope it goes in easy..
Old 01-31-2012, 08:52 AM   #792
77chris03
77chris03's Avatar
i think i got the temp gauge working. i think the problem may be with the headlight switch. the gauge works when heat is applied to the sensor, and falls back to cold when taken off. ill buy a new switch and see what happens...
Old 02-01-2012, 07:37 AM   #793
slick copper
slick copper's Avatar
Yeah man. I usually look to see what's going on too, just don't always have/know what to say. You're making good progress man. Can't believe you cut into that column! I'm sure you'll get it working good though.
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 02-01-2012, 11:19 AM   #794
butternut1972
butternut1972's Avatar
^^^^^Me Too. You have a great build going. I feel the same way sometimes about my thread. Keep up the nice work Bud!
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 02-01-2012, 01:25 PM   #795
nlped
nlped's Avatar
I just read this whole thing.... Looking great!!! Keep it up! Great inspiration, for sure.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-01-2012, 10:40 PM   #796
77chris03
77chris03's Avatar
thanks for the motivation guys....heres a small update on the truck...
Old 02-01-2012, 10:44 PM   #797
77chris03
77chris03's Avatar
got the volt meter installed and will only have to take the two existing wires for the ammeter on the pigtail and run an ignition hot wire...and ground of course...what yall think?
Old 02-01-2012, 10:48 PM   #798
VA72C10
VA72C10
VA72C10's Avatar
very nice!!!
Old 02-02-2012, 10:56 AM   #799
nlped
nlped's Avatar
Nice!
Carter
Old 02-02-2012, 10:59 AM   #800
Slick67
Sofa King Crazy!!
Slick67's Avatar
Chris, that looks great! Yeah, that's gonna happen to mine! Might be able to get my guages out this weekend if my back has healed enough. Definetely want to do that!!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
