Old 02-04-2012, 11:37 AM   #1
1978steven
1978steven's Avatar
Re: Extended cab window noise
From what I have found is it is not always the latch itself. The way the window is sealed into the door sometimes starts to separate from the door. I had this issue with my '01 and while riding in the back I could hold the latch like you did and what it was doing was simply pulling the window assembly tighter into the door. I noticed a decent amount of movement while doing it, so after getting it back home I did the same test but in the driveway. This time when I did it I could visually see the window assembly especially the weather seal area tighten right up into the door. Luckily a buddy of mine works at GM and helped me with the pulling of the window and resealing process. Not saying it's not the latch, but it's something else to look at to further troubleshoot...
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
