Brake shoes, old subject I know
I'm sure its been asked a hundred times but...........
Any preferences on brake shoes for a '72 4x4? Is there any particular kind to stay away from or ones that are best? What should I replace while I'm at it. I know to finish one before starting the other side but any suggestions or things to watch for is appreciated. Like lessons learned, I guess. Looked in FAQ section. Thanks
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
Cantankerous Geezer
With brake shoes, you usually get what you pay for. Don't go the cheap route. Replace the wheel cylinders when you swap out the shoes, for $10 each it's cheap insurance. My reasoning is that you usually get water and corrosion in the cylinders, and when you replace the shoes you push the piston back into a corroded area of the cylinder. It will probably fail soon. Purge your brake lines. First suck the remaining fluid out of the m/c, then refill and bleed until you get clear fluid at each wheel. Also, be sure to get your drums turned.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Also riveted shoes not bonded.
Rest in Peace Ed. Thanks for all the good times. |
I've used both riveted and bonded had no trouble with either, whats the advantage to riveted?, I don't do it but they recommend you put all new hardware on your new brake shoes when you change them, just check the hardware on yours, to see if it looks to be in good shape
Sometimes a bonded brake lining will come loose from the shoe, not often but why take the chance.
thanks, I see your point
What type of brake fluid should I use.......dot 3? Are Raybestos shoes the best?
huh?
![]() Join Date: May 2000
68 Suburban has praise dyno brakes on his burb, they're kevlar linings, and they stop on a dime. They don't wear out quickly like regular shoes either, but they're very pricey.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Cantankerous Geezer
On bonded vs. riveted, It's been so long since I knew of a bonded shoe coming apart that I've been using them. Once you've had to replace a drum due to rivet wear, you'll want to switch, too.
As for shoe brands, I have always purchased Wagner whenever possible. You just have to go with what's available. Most companies make different grades of shoes, talk to the guys at your local mom & pop parts store about which ones to get. On the kevlar shoes, they are supposed to be excellent, especially if your brakes are marginal. I will probably put them on my 52 when I restore it. http://www.praisedynobrake.com/ Brake fluid choice depends on a lot. For a daily driver most stick with DOT3, but it absorbs water and needs flushed every two years. If you are willing to replace all rubber parts, wheel cylinders, master cylinder and hoses (you probably need to considering the age of your truck), consider using DOT5, which is a silicon base fluid. http://www.fordfestiva.com/service/d...kefluid101.htm
A board member here had a bonded shoe come apart earlier this year for some reason. I agree with rivets tearing up drums but if you check the brakes routinely for wear......LOL. I know most don't think about brakes until they have a problem.
That Praise Dyno stuff looks pretty good. They don't mention anything for 8-lug setups on their website; is it safe to assume that they make kits for 3/4 and 1 ton Chevys?
Greg
No such thing as a stupid question, right? |
#12 | |
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Cantankerous Geezer
I just bought a rear cylinder 2wd at Autozone for $9. Made in Italy, Bendix brand on package. I hate doing business there, but my mom & pop shop is closed on Sundays.
#14 | |
very intersting
#15 | |
Cantankerous Geezer
#16 |
its all about the +6 inches
I agree that DOT 5 is for show cars only. The stuff will still let water in the system and corrode your lines and stuff. I've seen it first hand whn I was in the army. (we used the crap in all wheel vehicles)
Here is another site that goes a little more into depth about brake fluids. http://www.shotimes.com/SHO3brakefluid.html The carbon fiber shoes ARE made for the 3/4 ton trucks. I know this for a fact. I'll asume one ton trucks too. |
