02-04-2012, 06:44 PM | #1 |
So uh, what do you do when your truck is made of bondo??
Everything from the door back is almost completely constructed of Bondo, should I locate some new bed panels? Or just slap on a new pile of Bondo? Lol
I've been using a fine-bristled wire wheel that seems to cut right through the Bondo without damaging metal. |
02-04-2012, 07:24 PM | #2 |
Re: So uh, what do you do when your truck is made of bondo??
Looks like you may have a little more than a "skim coat"
Is the filler lifting in places?? or are you just cutting it down to metal? |
02-04-2012, 07:46 PM | #3 |
I found a similar bondo job on my truck. Im pulling it all off and starting fresh (actually fixing the problems), though this is tons of work.
I had around a quarter inch of bondo in most places on average.
Trevor "You already said spite" |
02-04-2012, 07:50 PM | #4 |
If the radiator cap is good, simply lift it up and drive a new truck under it. Works every time lol
02-04-2012, 08:07 PM | #5 |
Ouch. My 54 was like that. amazingly it only needed a number of fairly minor patches after pulling all the bondo off. I almost filled a 2 gallon bucket with the scrapings.
If you are up to the metal work, fix it and reward yourself with a truck that weighs 200 lbs less.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
02-04-2012, 09:24 PM | #6 | |
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
02-04-2012, 09:42 PM | #7 |
~Rest In Peace~
i would do a soda blast and get it down to bare metal and re work it from there
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
02-04-2012, 09:50 PM | #8 |
Bondo should be a controlled substance, you should have to provide proof that you are able to use the product as intended
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
02-04-2012, 10:18 PM | #9 |
The thicker the bondo the better...It adds a bunch of weight at the scrap metal scales.
02-04-2012, 11:20 PM | #10 |
02-04-2012, 11:28 PM | #11 |
Fabricate till you "puke"
Thats 1 way, but you could (as mentioned ) have her soda or plastic media blasted. See where the problems are & go from there....it dont look like its for the "faint of heart "tho....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-05-2012, 12:16 AM | #12 |
I would think if it has excess bondo ... then a good used fender might be the way to go...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-05-2012, 12:41 AM | #13 |
optomistic ah-so
Use the "Tom Sawyer" method, tell all the kids in the neighborhood that it's fun to remove Bondo...
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
02-05-2012, 12:44 AM | #14 |
Haha, that's just good stuff.
02-05-2012, 03:25 AM | #15 |
blasting will not pull the mud effectively, would cost a fortune. if the panels are damaged underneath, get new ones. I have seen a number of cars with way more mud than needed, but usually it is to hide problems
Mike Redpath |
02-05-2012, 08:43 AM | #16 |
Like Mike says,if it's bondo'd to fix damage,then replace the panels. If it's just excessive "blocking" get it off and move forward with what you have. Get plenty of dust masks and wheel/disc it off.
02-05-2012, 09:58 AM | #17 |
considering your location and the rep is that rustfree stuff is more available than in almost any place in the country
i'd use asis while looking for replacement panels and cab etc
02-05-2012, 12:33 PM | #18 |
Registered Cruiser
The best way I've found to remove gross amounts of body filler is with a heat gun. It's very fast, and much cleaner than grinding.
I intend to live forever. So far, so good. |
02-05-2012, 12:42 PM | #19 |
looks like sombody didnt want to do any bump work ...just went to dr phil
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
