01-31-2012, 03:00 PM | #1 |
Mirror barcket.where to find the right one?
hi there,last fall i purchased a steel rechromed mirror bracket for the left side off of e-bay and recently i purchased what was advertised as a chrome right side bracket from e-bay which turned out to be stainless steel which of course does'nt match but my problem is the left side bracket of course stands up high like the originals of course but the arm on the rightside bracket has a much lower angle on it so of course my 5x7 mirror has a portion of it lower than my window. does anyone know a seller that sells the bracket with the correct bend to the arm?other wise i'll have to buy another one that matches the drop like the right one.i would like them to be above the window glass like the originals. any ideas?
thanks! |
01-31-2012, 03:53 PM | #2 |
Re: Mirror barcket.where to find the right one?
LMC, Ecklers, Classic parts of America, Classic Industries, Truck Shop, Bow Tie Bits, Tim Tygerts Obsolete Chevy Truck Parts, Classic Truck Parts.......I would stay with the Stainless stell....never rust and easy to polish.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-31-2012, 05:27 PM | #3 |
hey thanks for the reply,but i guess what i am trying to ask is if anyone knows who makes the bracket where the arm goes more in a upwards direction like the originals.otherwise i will buy another one that the arm's angle is much lower.if all of the repop's are at the same lower angle then i'll have to settle with those.
01-31-2012, 05:58 PM | #4 |
Most of the repops are made by the same manufacturer. Have you compared it to an OEM part? Might be worth finding NOS part
01-31-2012, 08:16 PM | #5 | |
thanks! |
02-01-2012, 12:09 AM | #6 |
Senior Enthusiast
I have an original OEM mirror arm I picked up in a wrecking yard 20 years ago. It’s shown in the first photo. The arm in the second photo was purchased from Chevy Duty 14 years ago.
They both appear to be identical in shape. So I’m not sure searching for an OEM bracket will solve the problem. I don’t remember ever seeing an original style mirror arm or aftermarket replacement that is as tall as the chrome version you have. There are so many aftermarket parts that are not even close to original specs, I would suspect it’s likely the tall chrome arm is aftermarket. Hopefully another member has one formed in the same shape that can identify the manufacturer. |
02-01-2012, 12:04 PM | #7 |
thanks mark for the insight.you are probably right,i guess i better just order another stainless bracket to match the new one.
kent. |
02-04-2012, 01:14 AM | #8 |
If this is the one you want it was purchased from brothers. Posted via Mobile Device
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
02-04-2012, 09:37 PM | #9 |
1961 crewcab
I haven't seen any OE 60-66 to compare, but I know on the OE/repro 47-54, and the 55-9 the RH brackets are shaped different than the LH
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-05-2012, 02:19 PM | #10 | |
thanks for the picture! kent. |
02-05-2012, 02:21 PM | #11 | |
jon let me know what your doing tuesday morning,i thought maybe we could go to breakfast. kent. |
