Old 02-05-2012, 10:18 PM   #11
Andy4639
Old member
Andy4639's Avatar
Wink Re: Please someone explain the headlight relay mod
This is the easiest schematic I have found for them.
#86 will be either low beam are high beam which ever one you are working on.
#87 will be going to both headlights either L/H beam.
#85 is grounded to frame near relay Make it a good ground.
#30 is a fused source straight off the battery are unfused on the fuse block.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
fuse, headlight, mod, relay
