chevy truck fan
hey guys.....
well i am in the assy. after paint stage now & have a few questions: 1) when installing the painted doors do i install the door seals before or after I fit the doors to the cab??? along the same lines any help orhints/tips related to this would be very much appreciated..... ![]() 2) does the "latch assy." that bolts to the cab have to have the "shim" intalled or can the latch install to the cab fine with out it?? these are probably dumb to some, but i just want to try & do it right..... ![]() |
![]() Join Date: Feb 2009
Re: After Paint Build Questions...
subscribed and I have similar questions...
"Love Affair" Build Thread |
I am a Referee of life.
I think I would install and align the doors first.It just seems like it would be easier to get things lined up.However<I have a couple of old Army blankets and I would use them to prevent scratching.The weatherstrip may make the doors a bit hard to shut making assembly and alignment harder.This is of course just one opinion.The latch seems like it would be mor important to get adjusted properly than to leave the shim out(I'm assuming for appearance).You might trim the shim some to hide it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#4 | |
The Older Generation
![]() 2- Those are the striker plates. They can be installed without the shims but the doors may not close correctly. I always put the same number of shims back in that I took out during disassembly if the doors originally closed good. Install the strikers after the doors are on and lined up. They are adjustable in/out & up/down. To get them adjusted I only use 2 bolts, in opposite corners. Installation is trial & error so don't just put them on and slam the door or you may chip your paint or get the door stuck and not be able to get it open. Install the striker and hold the door handle button in while you slowly close the door. If you have another person hold a flashlight for you you can watch how the striker and door latch line up as you close it. With the button held in the door should close and open without rubbing on anything. LockDoc
chevy truck fan
locdoc,
thanks for the reply & helpfull hints. yea i first tried the search & almost word for word typed as you described, but i got a hundred threads (mostly in the build section_obviously) & the few i read mostly just covered the "bolt on" stuff after the truck was painted & assy. by a shop, that is why i went ahead & did another thread..... though i do usually try to search before too! ![]() ![]() ![]() ![]() thanks again for the help!! and more is always good to me so keep the hints & tricks commin' ![]() |
#6 | |
LockDoc
I would get some painters tape and tape off all of the door edges and anyplace that could get scratched and then remove it once the door is on and aligned to your liking.
chevy truck fan
Loc doc (leon)
will do....... Thanks!! Mak191, thanks!! Yea i have that figured already & bought 2 rolls of the painters tape..... |
![]() Join Date: May 2011
Be careful if you dont install the seals first. I would. I have no seals on mine right now and with the door centered nothing hits. But when you push the door Past closed (Since theres no seal to stop it) One side rubs the rocker and the other taps the rocker. My paint guy is actually making temporary stops that hold the door open a little bit until I get the seals and latches all installed again
#10 | |
LockDoc
chevy truck fan
thanks guys..... good tips!
Also make sure the tape you have is blue painters tape (not as sticky as regular tape) and when you remove it be very careful and go slow. When I painted my trucks I installed and adjusted the doors to fit before paint &drilled 1/8" holes at the hinges so when I rehung the painted doors I used a 1/8" x1/2" rivet and installed it in the pre drilled holes. Try using a floor jack& a carpeted 2x4 and a buddy to align the doors as they can be tough to balance on your own. cheers, Pat
chevy truck fan
pat,
thanks for the tips.... will adhere to the info. |
E.H.F.D Engine #2
Subscribing... some very helpful info here.
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
#15 | |
One of the First
![]() Join Date: Jan 2000
#16 |
chevy truck fan
guys.... thanks for the info. well the good news is the doors are intalled & only 1 small scratch! the alignment looks good but i still have not installed the door seals yet. the "bad" news is that i do not remember how to "install" the door latch portion that bolts to the cab
![]() any helpful hints!!! ![]() thanks!! |
