Old 02-05-2012, 08:43 PM   #1
bbc71
bbc71's Avatar
front spring ideas
i have a 71 chevy k20 with a big block. i put 2" lift springs in the front and it rode really stiff. i would like to keep the negative arch spring ride, any suggestions for spring combinations to get that amount of lift? or kit that you know of? or a block?
'71 chevy k20 cheyenne super 454.
here's the link to my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=496107
bbc71 is offline   Reply With Quote
Old 02-06-2012, 11:29 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: front spring ideas
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2012, 11:40 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have never heard anything good about using blocks in front, probably should cross that idea off your list.
What kind of 2" springs do you have? I'm using Softrides and it seems like a pretty decent ride to me. And that's with a 350 that weighs less than your big-block.
Maybe your shocks are the problem? And what about tires? For instance, E-rated tires at 80 psi will stiffen the ride considerably.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 02-06-2012, 12:44 PM   #4
rustyMUD
Originally Posted by bbc71 View Post
or a block?
Front lift blocks are illegal in most states, and definitely illegal in Michigan.
Look into some quality lift springs. You get what you pay for and this is often reflected in how the vehicle rides.
rustyMUD is offline   Reply With Quote
Old 02-06-2012, 02:55 PM   #5
msgross
msgross's Avatar
zero rate springs are only 1". You Could add that and a longer shackle and get close to 2". Check ORD or DIY4x.com for parts. Uses your stock springs so the ride would be better.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-06-2012, 09:20 PM   #6
76stepsidechevy
You could add an extra leaf or two to the stock spring, the thickness of the leaf alone will be about a half inch plus any height you get from the spring itself. I'd probably steer clear of shackles if your pinion angle and caster is good right now.
76stepsidechevy is offline   Reply With Quote
