Old 01-28-2012, 06:59 PM   #1
Holt
ride quality bag vs spring
which has a better ride? are they pretty close to each other?
Holt is offline   Reply With Quote
Old 01-28-2012, 09:12 PM   #2
broey
Square
broey's Avatar
Re: ride quality bag vs spring
depends on the set up, and the bag pressure, but... bags along with shocks ride really smooth. at least mine does. a lot smoother than the stock ride.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-29-2012, 04:34 AM   #3
andrewmp6
If its bagged right air bags will ride a lot smoother then a normal steel spring does.
Old 01-29-2012, 07:31 PM   #4
big_al_71
big_al_71's Avatar
from my own experience with my truck air bags are 100% smoother ride,,,,
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-29-2012, 07:53 PM   #5
Holt
thnx for the replies. i am border line clueless on bags, are some bags better than others or are u just paying for the name? also would i be able to piece together a setup cheaper than buying a kit?
Old 02-06-2012, 04:47 PM   #6
claytonisbob
Does anyone run bags for just a really mild drop, but more so for ride quality? I would think a simple cheap setup could be built to lower the truck a couple inches and just have a really smooth ride. I don't really care to slam my truck, but it would be cool to have something that rides really smooth. Most all of the systems I've seen are to put the truck in the weeds...
claytonisbob is offline   Reply With Quote
Old 02-06-2012, 05:13 PM   #7
OC 72
OC 72's Avatar
My truck is the first bagged ride I have ever had...was sceptical at first...but, these guys are right...if done right...it IS way better than a spring set up. Bags have been around for a long time.
OC 72 is offline   Reply With Quote
Old 02-06-2012, 06:03 PM   #8
SCOTI
SCOTI's Avatar
Check out RideTechs set-ups. They're designed for mild drop & improved handling w/o sacrificing ride quality. Porterbuilt also offers a similar 'mild' drop set-up for those that are not interested in cutting their truck up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
