Old 02-06-2012, 09:44 PM   #1
68short
68short's Avatar
Re: Will a s10 rear end fit my 70 C10 shortbed?
The axles are pretty easy to remove, first take the drums off, then take the rear diff cover off, remove the 5/16" bolt holding the pin-( use a 1/4" drive ratchet, as they sometimes snap using anything larger, your screwed if the bolt holding the pin snaps. If it snaps you'll need an easy out to remove the pin) return to one of the axles and push it in a little and the c-clip will sometimes fall out. If not then try to grab them manually
68short is offline   Reply With Quote
