Old 02-06-2012, 08:10 PM   #1
donkeypunch
header question
Peparimg to have my eddy done soon. Anyone know if the headers for a 2wd bbc will fit on a 4wd? Should I even bother with headers? Also I found a set with the smog tubes on them made by hedman and I'm wondering if I will get the same performance from them as a standard set....I like the tubes for future sniff test compliance.
Any thoughts would be appriciated.
donkeypunch is offline   Reply With Quote
Old 02-06-2012, 08:13 PM   #2
donkeypunch
Re: header question
That should say I'm preparing to have exhaust done.
Old 02-07-2012, 01:42 AM   #3
dugvera@gmail.com
dugvera@gmail.com's Avatar
Re: header question
Go with a good header if you do go that direction. 3/8 flange at the head. I only run dougs try y headers. Not cheap cuz they are not cheap. Get the smog tubes if your going to need smog. I used to pull my pump off every two years but I really see no change. Im also a 4x4 guy not trying to drag race.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
