Old 02-06-2012, 02:38 AM   #1
BigRed76
BigRed76's Avatar
Pedal Assembly Interchangeabilty
In the near future I'm going to be swapping out the SM465 in my '76 to a 700R4. I know that during this swap I will have to swap out the manual pedal assembly for an automatic pedal assembly, but I don't know which years of auto pedal assemblies I can use. Are all '73-'87 auto pedal assemblies the same or are there only certain years that will fit in my '76?
Thanks in advance for the help
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-06-2012, 02:56 AM   #2
85sierraclassic
85sierraclassic's Avatar
Re: Pedal Assembly Interchangeabilty
well all years will interchange from 73-87 far as i know, but you could save yourself alot of time and work if you just unbolt the pedel from the arm theres 2 bolts half way up the clutch pedel, sure youll still have a narrow brake pedel but it wont look as goofy and a clutch in and auto truck lol pry not the right way to doit but would work, but like i say i think they'll all interchange for 73-87.
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 02-06-2012, 04:14 AM   #3
ringger14
ringger14's Avatar
Ok here goes. I made these pics at 2 am so if I made some basic spelling errors I apologize up front lol. Im converting mine to a manual at the moment so I figured Id show you what I have experienced so far. Everything but the brake light switch bracket has been a direct swap. I did a test fit with a later model pedal assembly and it went flawlessly. Heres the pics. If you need any other shots let me know.
ringger14 is offline   Reply With Quote
Old 02-06-2012, 04:02 PM   #4
rcbildr
rcbildr's Avatar
I did the swap both directions in my Burb...from auto to manual and then back to auto. I can't remember what year the pedal assembly I used, but there were some subtle differences. They were very easy to deal with. IIRC one was the bottom two studs for the master cylinder had to. be changed and the other was the plate assembly that was for the brake light switch. When I converted back to an auto, all I did was unbolt the clutch pedal until I had the time to swap out the pedal assembly.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-07-2012, 11:24 AM   #5
BigRed76
BigRed76's Avatar
So it is possible to unbolt the pedals from the manual pedal setup and bolt in an auto brake pedal?
Zach
Old 02-07-2012, 01:48 PM   #6
C15_Sierra
C15_Sierra's Avatar
I did that on my '80...from the factory, the truck was a 250/3 on the tree, then when the PO swapped a 305/TH350 in, he simply removed the clutch pedal and kept the small brake pedal because the truck still had non-power brakes, which I found had a different pedal ratio than those with power brakes, and they never made a truck with an auto (bigger pedal) and non-power brakes.
Anyway, I ended up swapping in the wide auto pedal in the manual pedal assembly and swapped to power brakes at the same time. Everything bolted up nicely, no surprises.
Hope this helps!
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 02-07-2012, 01:51 PM   #7
BigRed76
BigRed76's Avatar
That is good to know, and will save me some work. Thanks for the help everyone.
Zach
