02-08-2012, 10:19 AM | #1 |
Should harness seatbelts
Is there a factory location for shoulder harness seatbelts or do I have to drill a hole. My truck is at the body shop so I cant walk out and look at it.
Thanks, |
02-08-2012, 10:43 AM | #2 |
I am a Referee of life.
Re: Should harness seatbelts
There should be a couple spots for the factory shoulder belts on either side of the cab.They are in the rear corners of the upper part of the cab.Some are covered with factory plugs made of plastic
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-08-2012, 10:47 AM | #3 |
02-08-2012, 10:52 AM | #4 |
Should be a plastic plug in the cab for that shoulder upper belt. So no drilling should be in order. (threaded)
A question I would like answered is if shoulder belts from other years will mount correctly in that location without modifications. Like S-10's or blazers etc. Since reproduction to fit our trucks are so costly.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 02-08-2012 at 10:53 AM. Reason: ! |
