02-07-2012, 09:01 AM | #1 |
Question who has built ccsb
For those who have build a ccsb i started mine on my 86 are y'all using the 4 center bed holes and then sectioning the front piece 2 use the factory front hole then cutting and re drilling the back ones any imput would b appreciated
Posted via Mobile Device |
02-07-2012, 09:53 AM | #2 |
Re: Question who has built ccsb
Sorry i havent had a chance to call you. The first cut needs to be behind the front bed bolt hole, the front and next to last holes will line up. Then you will have to drill the other two sets.
I measured back from the rear cab mount crossmember i think it was 7 1/2", that should put you just about a 1 1/2" behind the front bolt hole.Let me know if you have any other questions. Paul |
02-07-2012, 10:00 AM | #3 |
Formerly- 1972SuperCheyenne
I did mine the same way. Measured back 7 1/2 or so and made my first line. That way the factory frontmost bed hole is still in the original location and I dont have to worry about the bed not lining up right with the cab.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-07-2012, 08:58 PM | #4 |
Thanks I know ur busy do just before I go attempt this I wil be using the factory front hole in the frame and when I cut and weld it back together then the first 6 Will all b factory holes in the frame only the rear 2 will b redrilled
02-07-2012, 09:10 PM | #5 |
I dont have the bed back on mine but I think the front 4 will line up and drill the rear 4. Either way, as long as the front 2 are factory at least the bed will line up with the cab properly.
02-07-2012, 09:20 PM | #6 |
I had the bed sitting on mine with the 4 closest around the rear end in the holes just the front and back 2 wasn't there
02-08-2012, 08:28 AM | #7 |
Unless something is diffrent only the front 2 and the next to last 2 should line up. That's the way mine is. When you take the 3 1/2" off the rear you lose the rear hole and you lose the second set from the front when you take the 14" out.
02-08-2012, 08:30 AM | #8 |
Have you cut yours yet?
02-08-2012, 08:32 AM | #9 |
No just getting ready 2 lay it out
02-08-2012, 08:35 AM | #10 |
Post some pics after you lay it out if you have any questions. I might can get away to run by Sat. or Sun. before you cut it if you need me too.
02-08-2012, 08:50 AM | #11 |
Ok thanks I appreciate the help
02-08-2012, 07:25 PM | #12 |
how much overlap are yall getting i can get 4 inches without moving the spring hanger
02-08-2012, 11:11 PM | #13 |
Are you talking about where the z cut will meet?
02-09-2012, 04:50 AM | #14 |
Yes
02-09-2012, 10:16 AM | #15 |
I cut mine 3" to leave room for a fish plate without getting into the hangers.
02-09-2012, 10:34 AM | #16 |
Ok thanks
