Old 02-08-2012, 09:58 PM   #1
KRUSTY 51
KRUSTY 51's Avatar
What is it ?
Does anybody know what this thing is ? and how it works.
Thanks.
Brian.
'70 GMCHEVY
'51 chevy "tin woodie wagon"
IF YOUR CONFUSED I'LL USE smaller WORDS!
KRUSTY 51 is offline   Reply With Quote
Old 02-08-2012, 10:05 PM   #2
jocko
jocko's Avatar
Re: What is it ?
isn't that your egr valve? As for how it works, that would be classified as black magic...
Old 02-08-2012, 10:15 PM   #3
Willys47
Willys47's Avatar
Re: What is it ?
emissions? I belive it changed the timming under certain driving conditions
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-09-2012, 12:52 AM   #4
ls1nova71
ls1nova71's Avatar
Re: What is it ?
It's an emission part, It went inline in the vacuum line to the distributer, I believe it retarded the timing to keep the engine from dieseling when shutting it off.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-09-2012, 12:57 AM   #5
DanSan c 10
DanSan c 10's Avatar
Re: What is it ?
Good answer.
Why can't I find it until the last place looked?
65 Longbed 283 three on the tree.
66 Longbed 292 three on the tree.Pennys A/C
Trucks made in USA
Buy a much as you can, Made in the USA
DanSan c 10 is offline   Reply With Quote
Old 02-09-2012, 01:09 AM   #6
oklalawnboy
oklalawnboy's Avatar
Re: What is it ?
I didn't know what it was either.... I threw mine away.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 02-09-2012, 01:39 AM   #7
KRUSTY 51
KRUSTY 51's Avatar
Re: What is it ?
Thanks guys, It was hooked up with my old carb, vacuum lines and all. The new carb vacuum lines I ran direct to the distrubutor and pcv valve, then plugged all others. Now I just have to find where the wires come from so I can eleminate them.
Brian.
'70 GMCHEVY
Old 02-09-2012, 11:33 AM   #8
pumpkin
pumpkin's Avatar
Re: What is it ?
People that like to guess should tell you they are guessing. It is a selenoid that controles the vacume advance on vehicles with transmision controled spark. It would also alow vacume advance if the engine started running too hot.
pumpkin is offline   Reply With Quote
Old 02-09-2012, 11:48 AM   #9
dfwright
dfwright's Avatar
Re: What is it ?
I believe thats part of the TCS, transmission controlled spark system - a smog control. The vast majority of these I've seen referred to on the board were disconnected at some point in the distant past, including mine.
Those wires should run to a TCS relay under the dash by the fuse block.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
