Old 02-08-2012, 09:00 PM   #1
Snakester1
Snakester1's Avatar
BBC headers?
I need a set of 2" primary tube headers I have read some of you using chevelle headers. What do I want to run?
04 GMC CCSB SLT Duramax
78 Chevy 3500 454
68 Chevy C-10
98 Arctic Cat 1050cc 9.66/135 1/4 mile asphalt
Snakester1 is offline   Reply With Quote
Old 02-08-2012, 10:06 PM   #2
Willys47
Willys47's Avatar
Re: BBC headers?
I just installed a set of hooker headers #2455 they fit nice. If you plan on useing the stock shifter lincage it will be too tight for it to work the collector get in the way. One other not if you use ARP head bolts they are taller than the stock bolts so some light grinding of the flange will be needed to bolt to the head.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-09-2012, 01:42 AM   #3
Snakester1
Snakester1's Avatar
Re: BBC headers?
What linkage are you refering to? Man that thing looks badd ass in there I can't wait to get mine together
78 Chevy 3500 454
68 Chevy C-10
Old 02-09-2012, 10:36 AM   #4
Willys47
Willys47's Avatar
Re: BBC headers?
if you have an automatic trans is what I was refering to sorry for being unclear
Old 02-09-2012, 12:11 PM   #5
NoNeck
NoNeck's Avatar
Re: BBC headers?
My son Chad (CC69Rat) used Flowtech headers from Summitt Racing (I think). Maybe he will chime in with part numbers.
They fit really nice between the rails, but as Willys47 said with ARP head bolts you have to grind some clearance notches on the flanges. His are ceramic coated, but the coating could be more even and the factory polishing left quite a bit of residue in the tight recesses between the tubes. We used NeverDull polishing cloth and made them look much better. The good thing is that they don't cost as much as some of the other "name" brands out there.
He is using a Lokar shifter for his Turbo 400 and it works great. Looks sharp too.
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 02-09-2012, 12:30 PM   #6
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Re: BBC headers?
[COLOR="Red"]"I just installed a set of hooker headers #2455 they fit nice. If you plan on useing the stock shifter lincage it will be too tight for it to work the collector get in the way......" [/COLOR]
I have the same headers for my C10 BB with Auto trans. The PO resolved the clearance issue with the linkage by replacing the stock mechanism with a Lokar floor shift that bolts directly to the transmission housing. Looks great and is fully functional.
Al
'69 GMC 2500 Custom Camper
'69 Chevy C10 396 (Engine heading to dyno this week! )
alsriv2 is offline   Reply With Quote
Old 02-09-2012, 12:47 PM   #7
Snakester1
Snakester1's Avatar
Re: BBC headers?
I am going to install a TKO 600 behind my BB. I want to keep the stock clutch linkage if possible to save some $. My engine builder said I need to run a 2" primary I guess I could use 1 7/8" as well but can only find a Hooker set with 2" and the rest seem to be 1 5/8"
78 Chevy 3500 454
68 Chevy C-10
Old 02-09-2012, 02:13 PM   #8
custom1970
Member
custom1970's Avatar
Re: BBC headers?
Flowmaster makes 1 3/4", that fit pretty good, you'll have to work on the flanges with a grinder some though. Part # 11530 black, #31530 ceramic
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 02-09-2012, 03:17 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Re: BBC headers?
I have Hedman Elites, #69820. $325 w/ ceramic coating. They are 1.75" primaries, 3" collector. 1.75" or 1.875" primaries are plenty big enough, at least to 600hp, give or take, and will (probably) give you a little more torque than a 2" primary, especially below the 600hp range.
I will say that the hedman's are a TIGHT squeeze with '72 BBC mounts. These are all mockup pics w/o the cab on, but it will give you an idea of what you'll be working with if you do a BBC/TKO swap.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-09-2012, 05:18 PM   #10
Snakester1
Snakester1's Avatar
Re: BBC headers?
I heard you can't break in a motor with ceramic coated headers or most mfg's void the warrenty. Those are some sweet pics. I was going to get my trans right from hurst they say they have a TKO that will swap in perfect with no tunnel mods. I have a set of headman's on my 75 BB that fit real nice. I kind of think that 2" primaries are huge also. HP #'s are just a guess right now its 454 .040 over forged crank truck rods polished and peened KB pistons 10.5:1 comp big mutha thumper cam roller rockers milodon street flo valves 2.30intake 1.94 exhaust procomp 320cc square port heads matched intake edelbrock performer RPM air gap BG mighty demon 850 all was done by Mike Strasburg's brother Lindsey at Strasburg machine in Lindon UT. I figure if they can make their TF dragster go 300 mph I should listen to them.
78 Chevy 3500 454
68 Chevy C-10
